Worth the effort of fitting or just change cables more frequently?
Define "more frequently"...
I find cables last for years without lubing or changing.
Adjusters are there if you fit drops to a bike with slotted cable guides, because there won't be a barrel adjuster on the downtube like there is/was on road bikes. As for lubers - not really necessary on any other bike with a full length cable run so, not sure if you need them on a gravel bike specifically.
I rarely if ever change cables on my MTB with full length cables, I just apply a bit of silicone lube every 3-6 months. Shifting is still spot on. I think people change cables too often!
I just change them when they snap or suspect they're frayed, maybe once a year max. The outers are full length from shifter to derailleur so not really possible to re-lube after fitting?
I just change them when they snap or suspect they’re frayed, maybe once a year max.
I can't remember when I last changed a cable - many years. I do have in line cable oilers tho on runs where unhooking the cable to grease it is difficult. If its an interrupted run with slotted lugs I unhook it to gain a load of slack and grease the cable by sliding the outer up and down.
done like this cables will last an almost infinite time plus you always have perfect shifting
I've snapped a cable twice I think in over 25 years of riding.
TJ you grease cables? I use the lightest oil I can find.
If I can yes - only were you can unhook the outer and slide it along the inner on an interrupted cable run or when fitting new. Always been my practice. Cables only move a small ampount and grease will last longer.
It's my experience that thicker oils and grease gum up over time so it needs re-doing more often.
Sounds like my gear changes are not as delicate as I delicate and as I thought if I'm going through cables that frequently - although a years riding is anywhere between 2,000 and 6,000 miles though...
Definitely worth it for me. They've come into their own now I have separate road and gravel wheelsets and swapping between them needs half a turn or so first time out afterwards, but even so I reckon they're a no-brainer.
Edit: I'm referring to adjusters - had no idea lubers were a thing. Never lube my cables. Maybe I'm doing it wrong. I thought it just attracted dirt and gummed them up, and it was a hangover from before stainless cables with smoothed outer surfaces.
Cable oilers do seem a thing of the past but SJS still sell some
maybe i am a thing of the past as well but I love them
No one plutolining cables? (Sorry)
I put a cable oiler on a dropper post cable, as it's full-length and usually a pain to remove and relube. But not on gears, I suppose it'll depend on the routing (internal / external / full length etc).
