Indexing or somethi...
[Closed] Indexing or something else?
10 Users
A bit of help please.
3x9 setup
Doesnt matter what ring I'm in at the front. The cassette on the lower easier gears is fine. When in the bottom three hard gears when I pedal with a bit of effort it cracks like the chain is jumping. It's the only way I can describe it.the chain doesnt move to a different gear/sprocket. I have indexed the gears a few times but still get the same problem.
So far, new chain, new derailleur and new cable.
What could be causing this?
Thanks
Posted : 21/07/2020 11:11 pm
worn cassette
Posted : 21/07/2020 11:21 pm
1 Check mech hanger.
2 Is cassette worn?
Edit: Damn you bruneep!😁
I did check the cassette but it looked fine. None of the shark fin shaped teeth. I have a spare 9 speed cassette which I will try out.
I did eyeball the hanger, didn't look bent or out of alignment, bike hasn't been crashed or dropped. If changing the cassette doesnt do anything I will change the hanger.
Posted : 21/07/2020 11:32 pm
all our hangers were not straight
Posted : 22/07/2020 2:18 pm
probably either cassette or hanger, I've also installed SRAM chain links upside down before, so worth glancing at that as well. (although I think this is something that only really effects 11-12 speed chains or those with single use links)
Posted : 22/07/2020 2:36 pm
Worn cassette and chain - most likely...chain more so than cassette.
Posted : 22/07/2020 2:48 pm
outside possibility but had something similar recently and freehub was loose (but not that obvious) because cones not tight enough...def got big knock jumps on small out back
Posted : 22/07/2020 3:34 pm
most likely…chain more so than cassette.
Except he changed the chain! Cassette might not look worn, but might be worn enough to not mesh properly with a new chain. Could be your chainrings if not cassette, less of a chance if it skips in all three usually it's the middle one that wears fastest through most use.
Posted : 22/07/2020 3:36 pm
Totally slipped my mind but before all this happened. One day all of a sudden my chain went all loose. Like it was too big. It had been fine for months. This is the old chain I'm talking about. Thinking what the hell I removed two links and the gear problem was still present. Removed the derailleur, looked ok, the spring was fine, compared it to another derailleur I had and it seemed fine. That's when I changed the derailleur and chain. I tried the limit screw, checked everything by searching similar threads but nothing seemed to work. In the small chain ring and the hardest gear the chain was actually touching the chainstay.
Posted : 22/07/2020 9:05 pm
The derailleur is the only thing that takes up the chain tension, so that must have been knackered in some way. As you've replaced it, I think you can rule out that unless it's come to you broken.
Thinking about it, is the B screw badly adjusted so the top jockey wheel is miles away from the smaller sprockets? Could be there's not enough chain wrap, worth a try before the new cassette.
Posted : 22/07/2020 10:38 pm
The freehub is tight. Changed wheelset so double checked.
Followed the videos, small gap between jockey wheel and smaller sprocket.
Posted : 23/07/2020 6:51 am
When you say the chain was loose, was that during freewheeling? If so it would point to the freewheel binding and dragging the cassette slightly, which would cause the chain to sag if not pedaling.
Similarly, if the slipping has a metallic pinging/cracking noise that could be the freehub pawls slipping.
Other than that, does sound like the classic new chain slipping on old cassette problem.
First thing I'd do is put the old chain back on, it's worn the same as your cassette. If it fixes the problem, run the drivetrain until it's knackered.
Posted : 23/07/2020 7:14 am
New bike day....
Posted : 23/07/2020 7:15 am
need to get that thru my brain...don't think should happen...cross chaining was banned in our household just after we converted to natural gas so hard to picture...what happens big front with small back? ...seems to say to me need to check for bent hanger (if already ruled out I missed it)
Posted : 23/07/2020 12:46 pm
A bit of an update.
I tried a different cassette and the problem is still present.
Have ordered a new hanger.
Posted : 29/07/2020 7:16 am
Need photos Oldie! Try imgbb.com if you need somewhere to host them, and then paste the BB code option to here
Posted : 29/07/2020 7:19 am
