Inbred bottom brack...
[Closed] Inbred bottom bracket help please...
Hi,
I've got an old slidey drop out inbred which I want to run single speed with an old square taper fitting chainset. I'd guestimate running the chain ring where the big ring normally goes I'd need a 107mm length axle - does anyone know this for sure please.
Many thanks
Hicksy
Posted : 20/02/2009 10:52 pm
Need to know what chainset.
Posted : 20/02/2009 10:53 pm
Wow that was quick!
A 2000ish Truvativ Stylo Team (square taper).
Posted : 20/02/2009 10:55 pm
Seem to remember they run around 110-113 for normal use, so 107 on the outer is in the ballpark.
Posted : 20/02/2009 11:00 pm
recent stylos use 113mm.
but then again if you're using a geared wheel with single-speed spacers it won't make any difference what BB you're using.
Posted : 20/02/2009 11:03 pm
Thanks for the replies chaps.
Am using a single speed hub so sounds like a 107 or 110 then.
Posted : 20/02/2009 11:06 pm
