Or does it have to be a specific 24" wheel Fork- is there such a thing?
There are 24" forks, but I've not seen a decent one.
Two of my lads run 24" wheels, both use normal/26" forks - just means they have a bit more mud-room.
yes, need a 24" fork. They are available but tend to be low end stuff for kids bikes or very firmly sprung 'jumpy' things.
I think Scott and Kona both do some fairly high end 24" wheel kids bikes so might be worth a look to see what they use.
[i]yes, need a 24" fork.[/i]
Why?
coz otherwise it'l ride like a chopper ๐
But if you spec a 80mm travel will that not be ok - like fitting a 100mm
Or fit a travel adjust fork?
No.
the bike will have been designed for a rigid fork, most kids 24" bikes with suspension have between 40-60mm travel fork, not a 80mm fork designed for a 2" larger wheel.
not that hard to get your head round surely?
measure the axle to crown onthe existing fork - it's likely to be only 380mm or less. Addign 60+ mm of fork to the front end will bugger up the handling no end.
not sure what your kid is riding but unless it's pretty rough most kids are better with a lightweight rigid fork than a heavy suspension one their weight barely moves.
You can get a fork to work pretty well for kids even on kids 20" bikes with a bit of ingenuity.
