If so - how much are they worth? £35 posted? Trying to get a set of crank arms as cheaply as possible!!
SLX rings used to same inner ring as deore, but with an XT 'like' outer resin/aluminium outer ring. No where near £35 though, inner ring retails for like £9-12 and outer prob about £25 or whatever between deore/xt prices.
If they're a double I'll give you £20
Would be a triple
if its a triple I give you thirty for 3 posted
Flatback I will email you now
EDIT - can you email me robjackson@hotmail.co.uk
Steve_b77 - I have 2 SLX 24/38 you can have for that. Used twice btw...
yes mate I email you
patriotpro - I've got some M660 slx cranks, will your 24/38 rings fit them? I think I read somewhere about the newer shimano cranks having more material on the ring below the mount holes, causing compatibility issues?
Not sure winch tbh.
Not to worry, looking at them I don't think they'd sit well together, the M660s are much straighter looking if that makes any sense.
I do actually 😀 the 2x10 rings I have are quite bubbly looking due to the shifting ramps.
