If I need to replac...
[Closed] If I need to replace a cone on a Deore M525 hub...
Where do I get one and which do I need? Front right FWIW, the left is fine.
Posted : 21/09/2014 2:17 pm
Easiest way is to buy a new hub. They're dirt cheap and then you'll have loads of other spares too. Personally I'd rebuild the wheel onto the new hub though, because I can. 🙂
Posted : 21/09/2014 2:31 pm
do you mean a cup ? - I'd be surprised if you can't find a cone somewhere
Posted : 21/09/2014 2:34 pm
 nuke
What PP said. Did this with my rear XT hub...whole new hub including nice XT QR skewer was cheaper than buying the freehub by itself!
Posted : 21/09/2014 2:44 pm
@PeterPoddy - Probably. But I'd rather not.
@scaredypants - No.
Or cheaper still, buy a whole new wheel - of the same standard and durability - from Decathlon for £21.
Posted : 21/09/2014 2:53 pm
Yup, it's definitely the cone that's available separately!
Most LBS's will have them, easiest way is to take the old ones in as there's a couple of different sizes. If they don't have them, then google-shopping shimano hub cone brings up a few, but they're all £6+ from wheels manufacturing.
But as PP said, it's almost better just to buy a new hub off CRC or elsewhere, then swap everything, They're only £13.99 on CRC, and IME the freehubs only last a couple of years so if you've worn a cone out, the freehub won't be far behind.
Posted : 21/09/2014 3:06 pm
All sorted. £2.
Posted : 21/09/2014 3:08 pm
[url= http://www.sjscycles.co.uk/shimano-hub-cones-and-spares-dept422_pg1/ ]SJS cycles cone spares[/url]
