Ibis Mojo or turner...
[Closed] Ibis Mojo or turner 5 spot DW - Opinions and experience of both please
don't worry the drill is locked away 😆
Posted : 25/08/2010 3:25 pm
heihei -
Am demo-ing a Mojo HD back-to-back with my 5-Spot on Monday and will probably post some thoughts.
How was it?
Posted : 31/08/2010 8:04 pm
I'm curious as well. (a bit late now though) 🙄
How was your demo Mojo Deejay?
Posted : 31/08/2010 8:20 pm
On sunday I took it to the North York Moors without really checking the weather forcast - the wind was blowing so hard it was difficult staying upright!
1st climb (a deejay one 😉 ) and the front end was in the air - not what i expected at all but sliding forward onto the nose of the saddle kept the front end down and the rear gripped really well so I actually cleaned a bit I had not managed before so score 1 for the Mojo. Handling was fast and light but it felt really steep at the front going down hill and in fact was disconcerting - if I had the pressure in the fork set for my weight it was to steep and then too harsh with more air - not good. -2
I had it for monday as well so I decided to swap the fork over and fit my Rev 150 - the axle to crown was only about 15mm longer but I hoped it would do the trick - Went to Dalby (still windy!) The difference was amazing - it felt better immediately - even just riding in the car park.
Turned out to be an excellent bike - the Kenda El Moco tyres were very good and by the end of monday I was really enjoying it. Refitted the Fox 140's last night and had a quick spin before I took it back and it just did'nt feel right for me.
Now where can I try a 5 Spot?
Posted : 31/08/2010 9:14 pm
You can have a go on mine 😆
If you take both legs off from the knee down 😉
I would have thought a large spot would be available to test somewhere, small ones prove very difficult to track down, in fact impossible
Posted : 31/08/2010 9:43 pm
I'm shrinking as I get older - should be just about the right size when I'm 90 😆
Posted : 31/08/2010 9:54 pm
Just thinking about it, in order for me to have a go at a Deejay climb I would be looking for a bike with an engine. 🙄
Posted : 31/08/2010 10:16 pm
I would be interested to know the weights of these light Mojo builds, preferably the standard model. Also what forks/wheels were used.
Thank you so much.
Posted : 23/09/2010 1:20 pm
CG - the one I had on loan was a standard one in large - came out bang on 27lbs with XT - the wheels were Flow rims on Ibis branded hubs
Posted : 23/09/2010 2:23 pm
Mine weighs 12.36 kg, about 27lbs. Large painted standard frame, qr15 Float 140's, Ignitor 2.35's/Arch/ProII, Xt drivetrain and brakes, Joplin post and CB Acid pedals.
Potential to lose a pound or so by swapping out the post/pedals/tyres
Lots of builds and weights on the MTBR forum.
c_g, did you buy the small frame off the classifieds?
Posted : 23/09/2010 2:53 pm
Thanks for the replies, most useful. 🙂
I couldn't possibly comment. 🙄
Posted : 23/09/2010 3:37 pm
Do any of you Mojo riders use a chain stay protector? If so, which one please.
Thank you so much. 🙂
Posted : 11/10/2010 10:59 pm
Definately - otherwise the chainslap start to chip away the paint pretty quickly. I used the old cut-up inner tube trick.
Posted : 12/10/2010 8:01 am
I use ibis' own one. I also stuck a frame protector patch (lizard skins one) on the underside of the chain stay just behind the metal plate as this seemed to get a bit of damage from the chain.
Weight wise mine comes in about 29lbs with a Pace RC41 fighter, standard frame, XTR kit, hope on 719 rims and a maverick speedball.
Posted : 12/10/2010 8:34 am
Self amalgamating tape is your friend. Or the soft side of sticky velcro.
Posted : 12/10/2010 9:08 am
Page 3 / 3
