I think my frame�...
[Closed] I think my frame's rusted through - should I worry?
There's a few bubbles appeared in the paint on the seat tube about 2 inches below TT/Seat Stay junction - just below where the butting for the seatpost stops and the ID of the tube gets bigger. I pressed one with my nail and it sounds a bit 'crunchy' underneath.
I suspect the tube's rusted through from the inside.
due to the way the butting works I can't really see the point where the inside would be rusted.
I've got a 'big' ride Sunday and would prefer to ride this frame (SS) over my 456 so if I carry on riding it will I die horribly?
If it has rusted through like this is it fatal for the frame or do I just give it a clean out inside, spray some Dinitrol in there and press on?
Posted : 28/10/2010 2:21 pm
easy way to find out...
sand away the paint (its wrecked by rust anyway)keep sanding until there is no more rust. If you're left with a hole then you know the frame is a right off and you've saved your self from inevitable death. If its shiny metal then you are probably ok and you've got a new shiny bit on your bike.
Posted : 28/10/2010 2:24 pm
If its rusted through its f****d
Take a screwdriver to it, and on the basis that if the screwdriver goes through it was beyond repair and if it doesn't then it wont damage it, tap/press the rutsy area.
Wouldn't have happened if it was made of carbon.....
Posted : 28/10/2010 2:27 pm
Still not going to break straight away even if it is rusted through.
I like cynical-al's answer so I'll take that one ๐Ÿ™‚
I think next week I might need to get the dremel out and have a bit of a grind.
If they're just pin holes for now and I sort it out inside the tube and out should it be ok?
Posted : 28/10/2010 2:29 pm
most of the tubes on a bike frame are just there for decoration so it will be fine. put a sticker* over the dodgy looking bit for peace of mind
*depending on your age you might call this a decal.
Posted : 28/10/2010 2:37 pm
I'll get an 853 one just to be on the safe side.
Posted : 28/10/2010 2:39 pm
As meehaja says,
Then give it a couple of coats of Ronseal metal paint, or whatever it says on the tin, and keep riding.
Did this to a steel bike years ago after it rusted round the bottom bracket. Fine for the next 10yrs, then I sold it!
Posted : 28/10/2010 2:41 pm
IOf its rusting thru and there are pinholes on the outside how much metal has gone on the inside?
I wouod do the screwdriver of sandpaper thing before riding it
Posted : 28/10/2010 2:42 pm
wurst owtcum is it brekes so u get rustee mettal stuk up ur bumholl no nede 2 worey lodes of peeple lik that u culd get 2 lik it 2 if u praktise
Posted : 28/10/2010 2:50 pm
Bit of sellotape and it'll be fine ๐Ÿ™‚
Or if you're pretty sure it's near enough dead (eg it has rusted through - poke it with a small screwdriver as suggested - if it's rusted, it'll go right through), fibreglass/carbon fibre mat and epoxy wrapped around the damaged tube and a couple of inches either side, done tonight and kept somewhere warm will be plenty strong enough (though ugly!) by the weekend to keep it together for a few rides.
Posted : 28/10/2010 2:51 pm
thanks Mark - I was rather hoping it would expire gently rather than in a frenzy of 'where do I put the dressing?'.
On the salid
HTH
Posted : 28/10/2010 2:53 pm
[i]HTH[/i]
If I knew what it meant it may well do.
[not HTH, 'on the salid']
Posted : 28/10/2010 2:54 pm
well, I couldn't let it lie.
Just gone and had a poke around with a screw driver.
Initial investigation seems to show that there are a series of small, round pits in the frame but they don't go all the way through.
I wonder if there was some weld spatter or something when the bike was made and they've just filled the resulting holes with paint?
I'll have a sand/dremel around tomorrow and see if I'm right - hopefully I am.
So, where can I get touch up paint that's this shade of Orange;
aargh, I'm paranoid now - there looks to be a little bubble of paint just above the first chain link that crosses the seat tube.
Posted : 28/10/2010 3:34 pm
You're going to get killed to death!
Posted : 28/10/2010 3:36 pm
I'd be more concerned about that ugly oversize chain on those beautiful cranks and chain-ring. FFIW with no side play to consider Ive always found an 8sp chain to be perfect for SS use, in fact the only chain I have ever snapped was a singlespeed specific chain.
The frame doesn't appear very old to have 'rusted through'.
Posted : 28/10/2010 4:16 pm
1/8" FTW that one is ugly but who cares.
Posted : 28/10/2010 4:22 pm
sorry about the chain - was at the bottom of my parts bin and was used to replace a Gusset halflink chain that I'd had on there previously but was giving me grief.
I may well go for something more elegant in due course...
Posted : 28/10/2010 5:10 pm
very unlikely it's rusted through.
when the frame was painted/powder coated, it was probably not cleaned off properly, leaving contaminants. i had a frame which was clear coated. there was what looked like a thumb print on the down tube. it went rusty and started lifting the clear coat.
Posted : 28/10/2010 5:49 pm
get a titanium frame next time!
Posted : 28/10/2010 6:09 pm
Had a bit of a Dremel attack on it over the weekend;
the 'holes' don't go all the way through the frame but the paintwork was unbroken on the outside so not sure what's going on.
There's a similar collection down near the BB I've yet to do anything to.
put a bit of anti rust primer on there for now but it does look a bit scabby ๐Ÿ™
Posted : 01/11/2010 11:40 am
