The mount on the shifter ..... is it threaded or is the idea a bolt or stub locates in a threadless hole and uses a nut or male bolt.
Either way would it take an M5 bolt?
Posted : 23/10/2016 10:56 pm
No the thread is on the stub on the brake lever band, i've just converted an xt shifter from normal to i spec b with this kit
Sl-m780-b if you google it you'll get a pdf showing you the exploded diagram. I cant get the link to work sorry.
Posted : 23/10/2016 11:38 pm
It's a flanged nut that goes into a thread less hole. M5 bolt ok I think, could be m4 sized normally but if you're thinking of a bodge without the nut then an m5 should fit as there is room for the sleeve on the nut.
Posted : 23/10/2016 11:40 pm
