I deserve to be hit...
[Closed] I deserve to be hit with a big stick!!
18 Users
just returned from a cracking snowy ride and as I lifted the bike out of the flatbed of the pick-up i notice around the back wheel / shock area the snow is red/brown I notice fluid leaking from the back of the shock (its a fox brain shock and its leaking heavily from the brain part) so i bounce the bike to see if its ok...........rate of return is almost nothing and its squelchng really bad
phoned Mojo for advice.......chances are the seals are ****ed and they are now closed till 4th jan
two days before xmas and i break my bike!!!!!!!!! I now have two weeks off work with no bike to ride!!!
I'm crying as i write this.
Posted : 23/12/2009 1:58 pm
where are you? im sure someone somewhere will be able to lend a bike for some beerage?
Posted : 23/12/2009 1:59 pm
A clear argument on why everyone needs more than one bike.
+1
Posted : 23/12/2009 2:00 pm
I'd be looking at ways of replacing the shock with a suitably sized stick and ridign it as ahard tail for a fortnight.
There's a shock pump that's suppose to do that, not sure if it'll work for you though.
Posted : 23/12/2009 2:02 pm
 devs
+1. You need at least 3 spares.
The solution is a a no brain-er
Posted : 23/12/2009 2:05 pm
based in Hamilton in south lanarkshire, would consider taking it to a good LBS to be fixed if there were any around but as has been discussed previously Lanarkshire is void of any decent LBS that I know of.
only been back into mountain biking since jan and bought the sworks enduro 2nd hand to keep me going till i saved enough to go buy myself a 2nd bike (new) next summer. Hence currently only one bike
Posted : 23/12/2009 2:06 pm
New bike for Xmas. Problem solved.
Or buy a secondhand bike off ebay today, and re-sell next year.
Posted : 23/12/2009 2:07 pm
Xmas is already bought its lots of lovely new cycling gear that I will now not be able to use!!! (til jan)
Posted : 23/12/2009 2:11 pm
have you called Dales ? they may have something that could be swopped in
Posted : 23/12/2009 2:14 pm
Call the nearest LBS - see if they have a cheap shock on the shelf. Bang it on and viola - youre riding !
Not an ideal fix but will get you out of trouble.
Posted : 23/12/2009 3:27 pm
cheap coil? wedge it with a brick? Lock it out and ride rigid (don't know the particulr shock so don't know if this is possible? or.....
buy a fully rigid, fixed gear, belt driven, snow tyred, titanium bike. less to go wrong.
Posted : 23/12/2009 3:32 pm
Bit of steel rod with a hole drilled in each end. Instant hardtail.
Posted : 23/12/2009 3:56 pm
Put a classifieds ad up for an inbred frame local to you (£80 to £100 ish), get, build, ride, sell when your bike's repaired for the same price. Job done.
Posted : 23/12/2009 3:58 pm
On the face of it, that's a good idea. But then I got to thinking "it's a brilliant way to ruin the shock mount bolts"..... 😯
Posted : 23/12/2009 4:03 pm
Oh, purlease!
Posted : 23/12/2009 4:07 pm
Ditto PP - the shock mounts (not just the bolts) aren't designed to cope with impacts from a rigid rod rather than a sprung shock. Even when locked out there's almost certainly some give in the shock to round out the impacts. I certainly wouldn't other than a 'get you home' fix
Exactly the same happened to me two years ago. Brain shock'd SWorks Enduro. At the time only Mojo could deal with brain shocks, & it cost £130...!!!.
Pick up a cheap HT off here & flog on in Jan.
I've an old Kona but its only 16".
Posted : 23/12/2009 4:13 pm
girlfriend has a kona hardtail but its very small and im very tall, i think the build a hardtail idea is the way forward my first choice would be find a LBS who would do a service tho
Posted : 23/12/2009 5:20 pm
what about this ........mojo want 120 quid to service/ fix the shock plus shipping OR....I can get a new fox RP2 with pro pedal from crc for 100 quid??
fox brain shock vs fox rp2??????
Posted : 23/12/2009 5:42 pm
The shocks seem to be fairly cheap on e-bay at the rough size(+10mm was fine when I changed mine)
Posted : 23/12/2009 5:45 pm
Buy another shock over xmas on the credit card, sell old one after xmas and after rebuild - might cost a little more but easy option.
