So I’m 92kg and tried just taking a water bottle out the other day (620ml) and even thought it was only a short 90min ride I ran out pretty quickly.
But read on another forum that some people are doing like 50miles on one bottle! But then other scientific sights say 750ml per hour.
So what’s everyone’s take? Is it purely just a personal body to body thing?
I was going to try ditching the hydration pack but I think I would suffer more not having the fluids.
1 bottle & learn where you local taps are, there's even an app for this, but churches, scout halls, car sales places all serve me well.
everyones different.
depends on effort and conditions too.
i can do 2 hours at z2 and not drink a drip.
i can do 45minutes at threshold in heat and tank a bottle.
that said unless your diabetic, have poor general hydration or are not based in the UK (ie Your somewhere hot) you shouldnt need a whole bottle in 90 minutes , are you just drinking out of habit ?
Maybe it’s a habit thing. Mouth dry - drink probably too many gulps!
Mild uk weather - mainly 90mins and of that 60-70% hill work.
But also most long rides are early morning and my fluid intake hasn’t really been high by the time I ride.
As @trail_rat says, there's a lot of variables: temperature; humidity; your level of effort; your fitness.
Start off well hydrated and unless you are doing Z4 effort or it's 35C and 90% humidity* then you shouldn't need any drink for a 90min ride. So long as your urine is clear to a pale straw yellow then you are well hydrated. Note that drinking too much can also be detrimental - hyponatraemia is a serious condition that in extreme cases requires hospitalisation.
* Other random temperature and humidity values are available.
It's a personal thing, I know to avoid cramps and to get my required carb intake when racing I will drink a lathe bottle every hour or so. For example, at the Dyfi I took a 2ltr camelbak as I didn't want to stop at the feed station - it was also more than an hour to it - and in just over 3 hours I emptied it.
Don't use guides for pro/ elite level athletes as they are well trained in hydration management (although not immune to **** ups). If you felt thirsty in that time, with that amount on you, take more and work it out.
So out of interest the biking sites such as SIS, British cycling etc say you should intake 500ml per hour? Where do they base these kind of findings as if that was true we would all need massive packs!!
Are they making people drink more than they should?
I am overweight so that probably does not help!
Are those sites making the recommendations for general cycling or just competitive events? As @steve_b77 says many are guides for elite level athletes.
Try hydrating before you ride Drink as much as you can (within reason)
Yeah will give it a try, trouble is when I’m riding at 830 in the morning it’s not always easy to get a huge amount of pre ride fluid in without forcing it down!
One 750ml bottle lasts me about 2 - 2.5 hours at moderate effort. But I'll drink a pint or so before heading out, and will need to drink plenty post ride. So if I was looking to go further, I'd be looking to drink a bit more than that.
I've read/heard that the body is only able to.process 500ml of liquid per hour - hence that being the recommendation. This volume is irrespective of conditions (heat, humidity etc) so any additional fluids you need to take in are required before or after the ride.
Watermelon is great for getting fluid and carbs (sugar) in; so is a 50:50 fruit juice: water mix with a pinch of salt.
A key point to note is that it's salt that allows/causes the body to absorb fluid.
FYI I'm not a doctor, I've just looked into hydration & nutrition for personal interest.
Going to drink a bottle before I ride this morning and try be more economical with my drinking from the pack and see how much I go through!
On a hot day (20 degrees plus) I can easily get through a three litre camelback in an afternoons ride. I sweat like a fat bird in a cake shop though.
In the winter or on a milder day (say 15 degrees or so) I won’t even bother taking water out with me but I’ll drink a fair bit when get home. Having said that if I took my camelback with me then I’d probably drink it while I’m out.
Paranoi about not having enough liquid in me. Normally take 2 ltrs for a 3 hour ride and come home with lots of it left. Should really learn to take less, ration it a bit better, fill up more before I leave.
Moorland streams and steritabs anyone?
@seadog101 - take a water filter if you don't trust the becks. Something like the MSR Trailshot is fine for UK use.
Racing biased sites or brands selling hydration products ...?
I can drink 500ml an hour, or ride 6hrs steady on that much. There's no rule and it all depends on pace, heat, physiology etc. A combo of experience and piss colour is a better guide than a website generalisation that plays it very safe.
@spoonmeister - salt doesn't "allow" the body to absorb fluid. That's actually pretty dangerous advice.
Salt means the body *retains* water - because the salinity of your blood matters and your body doesn't like salty blood.
What happens is that your body retains water when your salt levels go up so your blood volume increases (and therefore it's salinity comes down). Of course this happens in a finite space - your veins and arteries - so hey-presto! your blood pressure increases.
That's OK occasionally but if you habitually take salt your body stays in a state where it's blood pressure is high - which is why your doctor and all the heart organisations say don't add salt to your food - because you get enough in your diet anyway.
If you're worried about losing salts on a ride then eat a banana - that contains potassium salts - which are more useful to you than sodium salt, which is what you buy in the supermarket.
Real food + water = win.
Interesting. Before I was sulking in Doldrums yesterday I was going to ask this question. I usually get through 1.5l over a 4h Marathon race but find I’m the only one of very few “racing” types that take a hydration pack (USWE in my case) but note it’s more common in the US Marathon scene to do so. I often wonder how the pros / others get through 3hrs with a single bottle in their frame.
Let's not forget that often people overhydrate to combat cramps.
More often than not for the general public at a recreational level they are cramping because they are unfit and are exerting above their capibilities and no amount of fluid is going to help.
Blimey, I seem to drink too much then. MSR water filter is ace, that and/or taps along route and it's job done. Tend to take electrolyte tablets for the water as well. Coed y brenin stream water tastes weird, maybe all the conifers?
Too many variables to be able to come up with hard and fast rules - temperature, humidity, effort and how well hydrated you are beforehand. Bottle an hour is a very general rule, sometimes I'd drink one in less if doing lots of climbing on a very hot day, whereas in winter one would last 3 hours at a steady pace. I once ran out of water on the Capital Trail and had to resort to drinking out a burn near the top of the Three Brethren - waited until I got above the treeline and checked for dead sheep! Made sure I drank some Coke at my next stop - not that it would have stopped a dose of crypto-spridium!
I always run out of water on the Whole Enchilada in Moab. This is generally warm to hot, and with low humidity, but also has a massively downhill bias, but altitude comes into play too.
This is a 3 litre Camelbak, and I always consciously prehydrate.
I run out of water on Porc. Rim, and emerge on the road crazed with thirst.
I'd drink a 1.5 litre bladder dry in 2 hours, you lose a lot or water as sweat (which sems salty stuff to me going by the taste and the residue on my helmet straps). I gave up with stuff like cytomax years ago when I realised humans can be effective fat burners. So I add a squeezed fresh lemon and a small pinch of himalayan salt (to replace lost minerals).
Once read advice to skiers to take a litre an hour, of course that will be altitude related (dry air), you wouldn't think they'd be sweating much.
Drink when I feel like it seems good for me, no cramps, might be over doing it a little as I do often need a pee when ariving home.
Works for me.
If I need to pee then I'd consider myself well hydrated. If you dont pee at all on a ride that could mean dehydration?
And yeah that pee should be at its strongest light straw coloured - although vitamins will colour it for a few hours after taking them.
Just my teaspoon full
In general i take a small 250ml bottle for a ride of 1-1.5 hrs, but will drink before and after too. Some times i may drink a small bit other times the whole lot... for longer, hotter rides i use my camelback and take about 1litre+ but rarely use it all. My last 3 hr ride i drank about 750ml of it (but probably should of had more but never felt thirsty).
We once did a guided ride from Chamonix with a guy called Farid Bourebrab, skinny as a rake & the fittest bloke iv’e ever met. It was a day ride, maybe 5-6 hrs of riding & while I drank 3 litres from a bladder + refills, he had a couple of slurps from a horse trough.
He didn’t appear to be sweating much either!
At least 1 pint at every pub you stop at, sometimes 2. Good to chuck in a Guinness every now and then if the lager is too gassy! 😆
Varies a lot. If you are big, you'll generate more heat for proportionally less surface area and hence need to sweat more and drink more.
If you're taking in carbs you'll need much more water to process the food. If I don't take carbs with me I hardly drink much.
If you are a slow twitch rider who rides for hours on fat reserves then you are probably skinny and don't feel the benefit from carbs so you'll hardly drink compared to a big muscly sprinter type attacking every climb just to keep the speed up, and eating to keep the performance up. And sweating buckets too.
Isn’t Guinness only for when you are hungry?!
I always think it’s better to have too much water with you, just in case. There’s not a lot worse than being thirsty.
I read somewhere that you should start exercising with 500ml in your stomach and then sip regularly ,as when you are thirsty there will be a delay between drinking and the water reaching your cells which reduces performance. professionals and elite amateurs will have less body fat, and I think defiantly need to drink and eat more frequently to maintain their peak performance.
That'll be the dead sheep/badger further up stream....
TBH a big part of it isn't about staying hydrated, it's also about comfort- you can be perfectly hydtrated but still feel a dry or dusty throat frinstance. Most of my rides would be fine with a bottle otherwise, but I drink a lot more than that.
I'm in the "probably don't drink enough" camp.
Eg today - did a lumpy 6hrs in the Peak on the gravel bike on a single 500ml bottle and a black coffee half way round. A combination of feeling like I'm sloshing if I have more than a mouthful at a time, and being completely disinterested in the contents of my bottle - tepid water or Torq holds zero appeal. Offer me a San Pellegrino Limonata or an ice cold Coke and it'll vanish in no time.
I also have a bad habit when working from home - I'll happily go from breakfast (glass of OJ, espresso) until the missus comes home at 6pm and sticks the kettle on for a cuppa, with no liquid passing my lips. I keep a water bottle on my desk, but if it's empty I can never be bothered to walk the 10 paces to the bathroom next door. An all day mid summer MTB ride, I'll probably get through most of 2l in my Camelbak, but I'll be more interested in the coffee from the café...
I'm at the skinnier end of the spectrum, which may help!
TBH a big part of it isn’t about staying hydrated, it’s also about comfort- you can be perfectly hydtrated but still feel a dry or dusty throat frinstance.
Definitely, there’s no point in drinking so much you feel it sloshing around. However the reverse is also true and by the time you realise you need water it’s takes a long time after drinking to take effect, so you end up drinking too much. Surely, it’s better to sip little and often?
Erm......maybe they get new ones given to them
Thirst is a pretty good indicator. If you feel like you need a drink, drink; don't try and reduce your intake just to comply with some sort of recommended average.
There's no single answer to this. I rode for 4 hours at a reasonable pace today, and managed comfortably on an 800ml bottle and a 500ml bottle, but racing in hot conditions I used to aim for an 800ml bottle every hour, if possible.
@kcr - what I was saying, and have probably expressed it badly is, if you drink little and often then you will stay hydrated without over drinking because when you feel thirsty you often drink too much to compensate. Also with this approach if you then still feel thirsty you can take bigger/ more frequent sips which will have a quicker effect because you were not dehydrated.
I certainly find that I don’t notice how thirsty I am and then it hits me and I have to drink a lot. The little and often approach works for me and then I can adjust according to pace/ weather etc...
Sure it's been covered but there is no "should".
Hydrate well before if possible, which will mean different things for different folk. I drink a couple of pints of water a couple of hours before a ride and you will pee out the excess and know you are hydrated (colour of pee).
Then simply drink to thirst. I am a big sweaty beast and so that probably means more fluid during the ride than other people.
That is essentially what I understand the latest science to say.
I don't think they do, a lot of marathon style bikes take two 750ml bottles now-a-days, unfortunately mine doesn't so if I intend to not stop I have to use the small camelbak.
If you can't get a 2nd bottle in the frame and don't run a dropper you can run a 2nd bottle on a post mounted cage.
I think it's more common in the US and Oz as it's a damn site warmer than it is over here. The MTB Marathon series rounds here have well spaced feed stations, that suit a 1 bottle approach - although I'll pack my pack at the weekend for Llandovery as I don't know the set-up yet and 100km is a rather long day out 😉
Once read advice to skiers to take a litre an hour, of course that will be altitude related (dry air), you wouldn’t think they’d be sweating much.
I do some big backcountry ski touring - there is no way people take a liter an hour. Would be far too heavy to carry!
You can be out for 8 hours, most of that climbing uphill... 2 liters is enough with a big drink in the morning and on return. You do sweat quite a lot hauling yourself uphill even in the snow 🙂
We as humans are not balanced on a knife edge of hydration and dehydration. We can be ok whilst being a bit thirsty.
I probably drank too little on Saturday- 4h ride in the sunshine and only did a 750ml bottle as didn't really feel like drinking more. Did have a second with me. Nailed a couple of pints of water when I got home, but then went to the pub and def felt dehydrated after a few pints of cider!
Member
Thirst is a pretty good indicator. If you feel like you need a drink, drink; don’t try and reduce your intake just to comply with some sort of recommended average.
I actually though thirst was a poor indicator - by the time you feel thirsty your already dehydrated.
For example https://www.bcm.edu/news/sports-medicine/thirsty-you-are-already-dehydrated
steve_b77/ kryton - there are some 2 bottle work-arounds available for single bottle full suss frames. The Lyne Holy Rail set up is particularly neat:
https://www.lynecomponents.com/blog
Thirst is an excellent measure of water needs; we've had millions of years of evolution to get it right and stay in good physical condition for running away from predators or chasing food to bring back for the family. The dehydrated Bushman can still chase the antelope until it drops, then gets to take a meal home afterwards, while probably still dehydrated.
As a medic in ultra-distance sports, I give out this simple advice every race: drink to thirst. That's it. Any salt in your drink or in your food intake is irrelevant compared to the kilo-plus that's already in your body. Over-hydration at events isn't just harmful, it can kill and does so remarkably quickly; I've seen and treated numerous hyponatraemic athletes.
Salt added to drinks is a false crutch; any fluid that you can stomach is still much more dilute than your blood, so you're still diluting yourself further.
Drink to thirst.
That’s interesting stuff. It would appear to be caused not only by excess water intake but also by excess loss of salts during extended activity. I don’t think what I was suggesting would cause this, but if I every do an ultra event I will be very careful.
I realise that the amount of water needed will depend on fluid and salt losses, has any body any idea how much you would need to drink to cause hyponatremia?
Yesterday at Cannock my urine in the pre ride slash was a faint yellow colour. I rode for 3 hours at a moderate pace and drank approx 2.3 litres of water, my post ride slash was dark straw coloured. To me this suggests I had not drunk enough.
Edit: I have never heard about adding salt to drinks as suggested, prior to reading this thread I would have thought it to be a bad idea.
I actually though thirst was a poor indicator – by the time you feel thirsty your already dehydrated.
I wouldn't suggested waiting until you are absolutely parched to have a drink. Once someone has a good idea of their personal fluid requrements, I think it is easier and more effective to drink the required amount by swigging regularly, particularly when racing.
I was thinking more about what the OP originally wrote. If he's going through X litres of water to quench his thirst, that's probably a good indication he does need X litres of water overall (rather than aiming to drink some specific amount dictated by a rule of thumb).
I tend to drink 500-800ml of water before heading out. Not in one go, more during the time it takes to get ready.
Will get through 300-500/hr in cool to cold conditions and easily double that in hot/humid. Will sometimes take a bottle of Torq and tuck into that when going harder.
However, I sweat a lot and therefore drop a pint of water with a High 5 electrolyte tab straight after. In certain conditions I’ll down another pint with or without protein powder.
IMO it’s not just what you drink when you’re out, it’s your pre- and post-rose I take too.
Varies enormously depending upon ambient temp, temp of water (ice cold water seems to help it last for me on hot days) and how hard you are riding.
Last year's heatwave was an eye opener for me, I quickly found that chasing PBs up cat4 hills at ~30C was a bad idea, I could go through the best part of one of my then two 750ml bottles while climbing for ~8mins and then recovering while descending over the next ~10mins!
This app might help you locate some places you can refill your bottle(s) while on a ride...
https://refill.org.uk/get-the-refill-app/
Lots of very interesting and differeing opinions!
I always drink a lot but as mentioned - maybe its habit, but for the most part its because I feel a little dry mouthed - not thirsty as such.
I need to try out maybe a 750 bottle rather than the 610 one. Not a huge difference I know. Maybe thinking of a clearer bottle too as I do like the 'sleek' look of a black bottle but maybe a clear bottle will make me manage my fluids better as you can see how much is there!
Then again, I have been comfortable drinking as much as I do for a while, so maybe its just how I am!
I found this article from Outside quite useful:
https://www.outsideonline.com/2148776/new-rules-hydration
'There’s an easy method to figure out exactly how much fluid you need: weigh yourself before you go out for an hour of exercise, and then weigh yourself again when you get home. That’s the weight of fluid you should be taking in per hour. As the saying goes: a pint’s a pound the world around. So plan to drink a pint, or two cups, of liquid for every pound you lose during exercise. For example, if you come back half a pound lighter, you should drink one cup of water per hour of exercise. Do this in a range of temps and intensities, says Sternlicht, and you’ll have guidelines to follow in every possible set of conditions. Just don’t take in substantially more water than you lose—that’s a recipe for hyponatremia.'
I like to subscribe the drink to thirst philosophy but there have been times, especially once where I was doing a long distance hike in Nepal where I was walking all day, was drinking to thirst and feeling fine, then I go for a pee and it's very, very dark yellow, showing classic signs of dehydration. I didn't even notice at all. After that I had to make an effort to drink regularly, even if I didn't feel particularly thirsty. It seems like it can creep up on you.
Interestingly - I read somewhere - (may have been a RedBull athlete interview with Gee Atherton I think..) that 1 litre for 1kg was recommended..
eight hour ride I will drink a litre or so. 3 hour ride I rarely bother at all tho I will have a 700ml bottle. Never been dehydrated to the point I can see a difference in my pee ( apart from at work!) even when riding when its hot
3 hour ride about 2.5l.
id like to just take a bottle but i cant see how..
Way too much andybrad - that way lies blood dilution and cerebral odema 8+ pts of water killed leah Betts
I'll get through about 2 to 2.5L in 3 hours, if I'm not pacing myself for a longer ride. Have tried weighing myself but even drinking that much I come back lighter. I get headaches and fatigue but reducing fluid intake doesn't seem to help, I think it's probably the helmet or posture.
really?
i tent to ride at max effort all the time (im slow and fat and im trying to keep up with mates) so i find drinking helps keep cramping at bay
Kelron - I bet you are diluting your blood, getting some cerebral oedema hence the headache and your body reacts by peeeing out water ( so you lose weight) to try to get blood back to its correct dilution
Seriously guys - some of the amoun ts of water you drink is absurd and potentially dangerous. 8 pts ie 5l of water can kill
Thing is its not forced, I'm not trying to take in some quota of water. I drink when I'm thirsty, and feel worse for it when I don't.
Just for you I'll try taking a couple of bottles out instead of a hydration pack and see how I get on 🙂
I drink when I’m thirsty, and feel worse for it when I don’t.
Fair enough. Its the people who think " I must drink a litre an hour" I am really aiming at.
Even working outdoors all day in Aus with temps in the high 30s I did not drink the amounts of water that some folk on here seem to.
I obviously drink too much then. Have done for past 3 years on the MTB and I’m not dead yet!!
I don’t get how some people drink so little! Maybe you have e-bikes or are just super fit.
The average fat bastard like me needs fluid as we sweat like pigs.
If I don't drink around 3 litres a day, I get quite odd symptoms when running. My vision is blurred around the edges and the inside of my cheeks get a strange numbness. I've had it a fair few times now, and it's definitely a lack of hydration that does it.
Worst time is a friday morning, if I've been at a track session the night before sweating buckets, then go for an early morning pre-work recovery run, I'm pretty much guaranteed to get it, only way to avoid it is to get up even earlier and get a litre into me.
So in that case, going 'by thirst' doesn't really work for me, as I'm not thirsty before I head out.
Don't really get it when cycling, but I very rarely ever push the envelope when biking compared to running tempo stuff regularly.
We're all different though, some folk don't seem to comprehend this, as per some of the 'you're drinking too much/too little' comments above. Local guy died doing Ironman Germany a couple of years back, his names still all over the top of the local strava segments, too much water and hadn't got his nutrition right sadly.
