Hubs with inter cha...
[Closed] Hubs with inter changable end caps
Hi everyone.
I am looking for some hubs where the end caps can be changed so when I decide to change frame and go boost I wont need a wheelset or a conversion kit which can be a bit untidy.
I know Hope do this on the Pro 4 hubs but is there any other alternatives, possibly DT?
Posted : 01/08/2018 1:03 pm
I think chris king is the way to go
Posted : 01/08/2018 1:09 pm
Any Boost conversion will be a bodge, because real Boost hubs have wider bodies. Rather than buying expensive hubs to convert them later, try using some cheaper hubs now.
Posted : 01/08/2018 1:30 pm
 Gunz
I just converted my Hopes to Boost using the MRP Boostinator and you immediately forget it's there after fitting, definitely not untidy looking.  I can't imagine the trails would be any more alive with a proper Boost hub.
Posted : 01/08/2018 6:04 pm
Chris King are very scathing of Boostinator type conversions so I'd steer clear of them if that's your end goal.
Posted : 01/08/2018 6:06 pm
 Gunz
What have CK said about the conversions?  It's not along the lines of, 'it's not fair, we thought we were going to make a ton of cash selling more hubs'.
Posted : 01/08/2018 6:49 pm
Any boost conversion kit will void your warranty so go 2nd hand.
Or just buy a cheapie to keep you running until you swap frames.
Posted : 02/08/2018 8:33 am
Unless you by Hope.  Then it won’t.
Posted : 02/08/2018 12:13 pm
 Gunz
I wouldn't worry about a warranty claim.  The conversion is so basic there really is no reason at all that a failure is more likely with one installed.
Posted : 02/08/2018 1:06 pm
