Trying to get a definitive answer on this is a ball ache. Can I use shimano mineral oil (that I use for my brakes) or should/can I use wet lube such as Finish line for my mavic rear hub? What do you use?
Posted : 16/04/2014 3:20 pm
Grease is the word
Posted : 16/04/2014 3:24 pm
Mmm not sure the pawls would like that.
Posted : 16/04/2014 3:27 pm
Mineral oil has no other use than the brakes. Grease for ball bearings and freehub, the pawls will quite like it and will quieten down for a while!
EDIT - lube doens't have a use for hub servicing, only ever use grease
Posted : 16/04/2014 3:32 pm
According to Mavic I should be using Mineral oil. According to my lbs I could use finish line (as an example).
Been told not to use grease as its too heavy a medium and will clog up parts and generally mix with any dirt that gets in...along with invaildating the warrenty.
Posted : 16/04/2014 3:58 pm
