Hub dynamo info req...
[Closed] Hub dynamo info required.
 MSP
I am building up a commuter/tourer/general purpose bike with a hub dynamo.
From the hub dynamo I will want to run a front and rear light, and some sort of usb charging port for sat nav. I don't expect to be running lights at the same time as charging other stuff, so power drain shouldn't be a problem.
Anybody done this kind of setup? I would like to keep it as clean as possible. Is it possible to charge a Germin unit from the output of an exposure revo?
Are there any decent alternatives to the revo that are permanently wired and fixed?
Posted : 13/09/2013 9:52 am
I've got the SP PD-8 hub, wired up to an Exposure Revo. I run an Exposure Redeye from the Revo's smartport thingy.
For charging, I've got a [url= http://www.kemo-electronic.de/en/Transformer-Dimmer/Converter/M172N-Bicycle-Power-Charge-Controller-USB.php ]Kemo M172N[/url] which connects inline between the hub and Revo if I need it.
I've also got the previous model M172, but I snapped the USB plug on it and bought the replacement/upgrade rather than wiring ona new wire as I needed it in a hurry (for the LEL)
Happy to fix and sell the M172 if you're interested...
Posted : 13/09/2013 10:05 am
 MSP
How does that fit inline? Does it use the same connectors as the revo or do you have a whole separate wiring harness?
Posted : 13/09/2013 10:09 am
I'm building a similar setup at the moment. I have on pre-order the Shutter Precision PD-8X which is the 15mm axle version of the hub that exposure have re-branded and sell with the Revo.
http://www.sp-dynamo.com/8seriesdynamo%20hub.html
I was looking at getting a Revo and either the plug2 ( http://www.en.tout-terrain.de/accessories/electric-power-supply/) or the Light charge ( http://www.bike2power.com/lightcharge-bicycle-hub-usb-charger.html) However in the wiring department these don't seem to be that neat a solution. They definitely work but I think there is more graceful ways of doing it.
I'm also looking at k-lite Australia for their lights and a USB switcher as a possible alternative.
http://www.klite.com.au/ (half finished site)
https://www.facebook.com/kLite.com.au
Posted : 13/09/2013 10:11 am
I've wired in 2 pairs of these:
So I can run just the light, or fit the Kemo in to give me the option of the lights or charging.
I used the setup for riding the LEL the other month, using an phone as a GPS and had no problems.
Posted : 13/09/2013 10:54 am
 MSP
Ooooh what connectors are those?
I wouldn't mind seeing some pics of your setup if possible.
Posted : 13/09/2013 11:37 am
Waterproof LED connectors from [url= http://www.ebay.co.uk/itm/LED-Strips-Lighting-Waterproof-Power-Connector-Cable-3-5mm-x-1-35mm-/190895853837?pt=UK_Light_Fittings&hash=item2c7247910d ]ebay[/url]
I'll link pics when Flickr is back online...
Downside of the Kemo is its a little bulky so lives in a top-tube bag on the bike.
Posted : 13/09/2013 11:53 am
 MSP
Looking at the exposure website, it looks like it is possible to charge straight from output port.
http://use1.com/exposure-lights/accessories/smart-port-plus/boost-cable
That certainly would be a neater solution.
I have sent exposure a message to see if it will work.
Posted : 13/09/2013 12:00 pm
If you want to keep it clean, how about a light with a built-in USB port, so you can choose whether charge or illumination?
[url= http://www.bike-discount.de/shop/k1004/a86942/luxx-70-plus-steady-auto-led-scheinwerfer.html ]Axa light[/url] - the nano version is cheaper, but less bright.
Posted : 13/09/2013 12:04 pm
Here you go:
[url= http://farm8.staticflickr.com/7447/9495122333_e0ca640ac9_b.jp g" target="_blank">http://farm8.staticflickr.com/7447/9495122333_e0ca640ac9_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/ir_bandito/9495122333/ ]DSC_0135[/url] by [url= http://www.flickr.com/people/ir_bandito/ ]ir_bandito[/url], on Flickr
Kemo is in the bag on top as mentioned.
Fork-crown mount is made from an old brake adaptor:
[url= http://farm9.staticflickr.com/8558/8807463986_61f00f81f3.jp g" target="_blank">http://farm9.staticflickr.com/8558/8807463986_61f00f81f3.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/ir_bandito/8807463986/ ]DSC_0697[/url] by [url= http://www.flickr.com/people/ir_bandito/ ]ir_bandito[/url], on Flickr
Posted : 13/09/2013 2:13 pm
I have the setup you are after on my MTB, I have used it racing, all day epics, multi-day bikebacking touring and day to day commuting.
I have tried a few different chargers, but fur ruggedness, mall size and value for money, I would recommend the Kemo 172, you need to cut and connect the wires into the Exposure cable, but well worth the fuss. The Exposure Boost cable will keep a Garmin charged, but would struggle with a smart phone, plus I recommend using the power port to connect to the long cable redeye rear light, so you have a dynamo powered, sper bright, rear light too.
There's some more info here:
[url= http://singletrackworld.com/forum/topic/that-there-exposure-revo-light ]FORUM DISCUSSION WITH MY SETUP & AIDAN HARDING'S IN[/url] (both MTB setups, for racing, not the normal touring setup)
[url= http://robdeanhove.blogspot.de/2012/07/racing-on-dynamo-charging-my-gps-bright.html ]BLOG ENTRY SHOWING MY SETUP[/url] (with similar, but no longer available, Softhema charger)
My Revo light with standlight (after a few minutes to walk the bike across the beach)
Also, here is a pic of Phil Simcock's setup for the Highland Trail 400, Exposure Revo + Kemo 172 to charge the Garmin in the day:
[url= https://twitter.com/Spillippe/status/336206255767052288/photo/1 ]CLICK HERE[/url]
Hope that helps!
Posted : 19/09/2013 8:09 am
