HRM watch for Strav...
HRM watch for Strava- recommendations for budget options
[#12892714]
I've had a search but no clearer unfortunately. I want a watch that can provide some heart rate info for my rides.  I use my phone for logging the rides currently which is fine so I'm not sure if I can continue with this and add HR data or if I need a watch/HRM that can also record the ride (GPS enabled).
I'd like to keep the spend sensible as this may well just be a novelty feature, any recommendations that are tried and tested?
Posted : 17/07/2023 3:25 pm
You could get the £20-ish Halfords Bluetooth HRM chest strap and monitor - you should be able to connect that to your phone and it should be recorded if your recording app supports it.
https://www.halfords.com/cycling-technology/heart-rate-monitors/halfords-heart-rate-monitor-and-chest-strap-668211.html
Posted : 17/07/2023 3:29 pm
reeksy reacted
If you aren't too worried about tracking it 'live' (or you have your phone mounted where you can see it) - you could borrow/buy a Bluetooth heart rate strap and simply pair that with your phone.
It would be a lot cheaper than a cheap GPS/HR watch anyway !
beaten to it by DickB !
Posted : 17/07/2023 3:30 pm
I don't normally beat anyone...the excitement isn't quite at the level I ever though it would be... 😉
Posted : 17/07/2023 3:32 pm
As above, a chest strap will be more accurate too.
Otherwise the standard answer is a 2nd hand Garmin Instinct off ebay for ~£50, the watch HR's aren't as accurate, but I hardly ever use my phone for logging rides anymore as the watch is just more convenient.
Posted : 17/07/2023 3:35 pm
I did try a bluetooth HR monitor paired with my phone for Stava/HR but it kept dropping out.
Now I use a Amazfit watch which does HR and tracking together, upload to phone at end of ride, pretty simple and so far faultless. It's rubbish as a bike computer but great for GPS tracking for Strava.  They start at about £50.
Posted : 17/07/2023 3:39 pm
GPS bike computer and a generic  Ant+/bluetooth chest strap for the win.  I got fed up with  Strava  draining the battery on my phone with the always on GPS within an hour, whereas my Wahoo Bolt has a 15hr battery life. The only time a wrist based solution is better is for runners.
Posted : 17/07/2023 4:05 pm
... the standard answer is a 2nd hand Garmin Instinct off ebay for ~£50...
Or Broaden the search to other models a My spare watch is a VivoActive 3 which is pretty basic by current standards but would do the job of logging a few hours bike riding no trouble, as would lots of the various Forerunner models.
You can score something off eBay for ~£30 on a good day.
Basically just about any 2nd hand Garmin off Ebay, budget for a fresh strap (fiver or so off Amazon) unless you want to use someone elses sweaty old strap...
If you want greater accuracy get a chest strap, if you want to be in the right ballpark and have a wee bit less faff rely on the watches' optical sensor. Basically just about any Garmin from the last ~6-7 years will probably do the job. as with any electronic item, battery life will have diminished over time...
Do check the DC Rainmaker review for anything you find before bidding/clicking 'Buy it Now'
Posted : 17/07/2023 4:19 pm
 scud
The Wahoo watch is £199 new on their website currently
Posted : 17/07/2023 4:22 pm
I got a s/h Garmin 6 a year ago, not used either my phone or Garmin 820 to record a ride since.
Just works and brilliant battery life.
Posted : 17/07/2023 4:25 pm
+1 Amazefit Neo
you still need to ride with your phone, but i always do anyway
mine was £20 and its not missed a beat (boom-tish) over the 2years or so ive had it
app is not too bad either, synchs with strava automatically and battery lasts for ages
Posted : 17/07/2023 4:30 pm
