How to remove sproc...
[Closed] How to remove sprocket from salsa free hub?
How do you stop the free hub spinning to undo the sproket?
[URL= http://i163.photobucket.com/albums/t310/schoey_photos/12346B3F-7472-41FB-B002-E5D733E12299_zpsn8piom3a.jp g" target="_blank">http://i163.photobucket.com/albums/t310/schoey_photos/12346B3F-7472-41FB-B002-E5D733E12299_zpsn8piom3a.jp g"/> [/IMG][/URL]
[URL= http://i163.photobucket.com/albums/t310/schoey_photos/D0B8077F-080B-460D-9F79-67032C47F7C8_zpsibbzhhrs.jp g" target="_blank">http://i163.photobucket.com/albums/t310/schoey_photos/D0B8077F-080B-460D-9F79-67032C47F7C8_zpsibbzhhrs.jp g"/> [/IMG][/URL]
Posted : 21/02/2014 6:10 pm
[url= http://www.chainreactioncycles.com/x-tools-chain-whip/rp-prod10184?utm_source=Google&utm_medium=Shopping&utm_name=UnitedKingdom&gclid=CPnGipnc3bwCFSTMtAod6HgApQ ]A chain whip..[/url]
You hold the sprocket with the whip, insert the lock ring tool into the end of the freehub, undo it with a spanner and slide the sprocket off the freehub.
[url= http://www.chainreactioncycles.com/shimano-cassette-c-lock-lockring-tool/rp-prod23751?utm_source=Google&utm_medium=Shopping&utm_name=UnitedKingdom&gclid=COSK_Knd3bwCFYMfwwod0zMACQ&gclsrc=aw.ds ]Lockring tool..[/url]
Posted : 21/02/2014 6:13 pm
Ta! Got both the tools but can't figure out where the locking tool engages with the free hub. Do I have to take the axle out?
Posted : 21/02/2014 6:22 pm
Yes, take the QR out,
Posted : 21/02/2014 6:24 pm
is that a track cog threaded onto a freehub? If so you'll need an old cassette sprocket to thread onto the freehub and a 2nd chain-whip. One to turn the track cog and one to hold the freehub straight.
Next time get a singlespeed sprocket and slide it onto the splines.
Posted : 21/02/2014 6:29 pm
[URL= http://i163.photobucket.com/albums/t310/schoey_photos/03991EEB-1186-421E-89FA-A4FFD0AFCD7A_zpsdz5dvpwd.jp g" target="_blank">http://i163.photobucket.com/albums/t310/schoey_photos/03991EEB-1186-421E-89FA-A4FFD0AFCD7A_zpsdz5dvpwd.jp g"/> [/IMG][/URL]
Posted : 21/02/2014 6:30 pm
It looks like the sprocket is threaded onto the freehub, rather than sliding on the freehub over the splines like a normal one,
The tool normally goes into the end of the freehub, unless it's a different tool for those hubs..
Posted : 21/02/2014 6:35 pm
Is that threaded on or slid on? They should be slid on with a track lockring to hold it in place. So if youve managed to remove the lockring it should just slide off.
They're not the same as normal hubs with spacers and a cassette locknut.
Ive got the same hubs.
Posted : 21/02/2014 6:37 pm
[url= http://singletrackworld.com/forum/topic/what-tool-for-threaded-freehub-lockring-removal ]Aha..[/url]
Might make more sense..
Posted : 21/02/2014 6:50 pm
It's a single speed specific wheelset from a salsa bike i picked up 2nd hand.
The free hub splines are threaded and comes with a lock ring.
I did try a non threaded single speed sprockets from my other wheelset but they felt really loose. That's why I thought I'd try the threaded sprocket.
Looks like I've cocked up somewhere!
Does anyone else run this type of hub?
Posted : 21/02/2014 6:52 pm
like I said you should have used a normal single speed sprocket and the lockring. Only way thats coming off now is another normal sprocket on the remaining splines and 2 chain whips.
If it was loose you missed out a singlespeed spacer or should be using a wide based sprocket anyway.
Posted : 22/02/2014 2:17 pm
