How to remove round...
[Closed] How to remove rounded off 3mm hex bolt?
Fitted some new grips the other day, using torque wrench set to 2nm as on carbon bars. First side was fine, then on the other side the little b@st@rd rounded off straight away
Any suggestions on how to get it out? Have tried three different Hex keys so far with no joy
Posted : 11/05/2017 11:10 am
Drill
Posted : 11/05/2017 11:11 am
T15 Torx key? Maybe try tightening the screw a bit 1st too
Posted : 11/05/2017 11:12 am
torx bit hammered in often works, otherwise as steve writes.
T15 Torx key?
Have one of those at home, will try tonight
Posted : 11/05/2017 11:13 am
Do what with the drill though?
Posted : 11/05/2017 11:14 am
drill through where you'd put the hex key - you just need to remove the head of the bolt, so a 4mm drill should suffice (a 3mm hex head usually means an M4 bolt IIRC).
Posted : 11/05/2017 11:18 am
As the head is removed it will relive the pressure in the clamp and you can then remove the grip.
If it was an ali bar I would suggest pulling it off.
I take it its not the end clamp? you could hacksaw the bolt if there was enough thread showing.
Posted : 11/05/2017 11:25 am
If the grips don't spin, why remove it? Wait until the grips wear out, then drill it.
Posted : 11/05/2017 11:35 am
Whack an old torx bit in, slowly twist. I have done this way more often than I should, bit of a knack but you'll get it - I have a box of torx bits that I use for this purpose.. Small hex heads are pretty poor imo, anything over hand tight can be a pain to remove, worthwhile greasing the threads.
Posted : 11/05/2017 11:38 am
No need to drill. It's a pair lock on grips, you should be able to see the bold threads. Just cut it in the middle with a hack saw.
Posted : 11/05/2017 11:49 am
I'd use an easy out.... or if the head sits proud cut a slot in it and flat blade screwdriver it out.
Posted : 11/05/2017 11:52 am
It's the bolt on a set of dmr deathgrips.
Not enough space to hacksaw
I want to reposition the grip as it's not quite right for me at present (waffle bit up a bit too high)
Posted : 11/05/2017 11:54 am
If it's proud enough, use a drill chuck to clamp on the outside of the bolt head.
Picked that tip up from here and it's worked a treat a few times.
Posted : 11/05/2017 11:56 am
It's recessed unfortunately. That's a good idea if i round something proud though
Posted : 11/05/2017 11:59 am
Can you cut it with a dremel rather than a hacksaw, might be easier to get to it?
Posted : 11/05/2017 12:26 pm
http://www.screwfix.com/p/trend-pro-grabit-screw-and-bolt-remover-2-pieces/21391
Saved me loads of times, cleat bolts, oven fan rusted bolts etc.
I think it is called an easy out (already mentioned by scrumfled)
Posted : 11/05/2017 1:09 pm
 poly
Torx bit is my first step in this scenario - but I recently had a really nasty aluminium screw where even that didn't work. I put some superglue in it and glued a bit in place and that was enough to stop it skipping out. Worth a try.
Posted : 11/05/2017 2:04 pm
 tonj
As mentioned above, easy out's:
https://www.amazon.co.uk/Hakkain-Extractor-Broken-Damaged-Remover/dp/B0185PAL4Q
I used a set like this many times to remove knackered hex/torx bolts. There's also this type: http://www.ebay.co.uk/itm/small-Screw-extractor-stud-bolt-removal-tool-easy-out-set-engineering-remove-/290489660177 but i've had less success with these.
Posted : 11/05/2017 8:31 pm
Dremel a slot- 30 second job.
Posted : 12/05/2017 3:14 am
