how tight do qr nee...
[Closed] how tight do qr need to be
just serviced my mates bike & it took me all my might to undue his rear qr.
personally i do mine untill i feel a little resistance at the half way point.
can you actually over tighten a qr, he is a large hefty chap so his tight & my tight are probably way different.
is there anything that could get damaged by over tightning ie hub bearings.frame or anything.
Posted : 26/09/2009 5:22 pm
Cup and cone hubs or cartridge bearings? You can compress the axle slightly so could in theory overtension cup and cone hubs. A good cartridge bearing hub wouldn't suffer in the same way though.
To me, tight has always been governed by can I undo it again? As you say, normally, you feel the cam action kick in at 90 degrees. Or, another way is it leaves an impression in your palm for a moment. Too tight and you might snap the rod or strip the threads out of the nut the other end.
Posted : 26/09/2009 5:39 pm
they are cartridge bearings.
Posted : 26/09/2009 6:02 pm
Then his only risk is breaking the skewer or nut
Posted : 26/09/2009 6:16 pm
as above should leave an impression on your /palm and be capable of being undone without a lever!!!
Posted : 26/09/2009 6:23 pm
