How stretchy are la...
[Closed] How stretchy are latex tubes?
Using a 28c in a 33c tyre level stretchy? Can’t seem to find anything bigger than 28c so assume they must be fine?
Posted : 05/10/2017 6:53 am
No problem. Stretchier than a stretchy thing!
Posted : 05/10/2017 7:02 am
Good news then! Was concerned by the thin walls, but i’ll crack on in that case!
Posted : 05/10/2017 7:40 am
I'd heard folks moan about the fragility of latex tubes !!
I'd fitted latex tubes to my Sunday best wheels few years ago and hadn't noticed a tiny bit of the tube had popped out between tyre/rim 😳
I proceeded to pump it too 100psi and only on spinning the wheel I noticed .. It held fine no drama.. Quickly deflated and sorted and not a puncture in over a year before switching to tubeless ..
Posted : 05/10/2017 7:51 am
Latex tubes are great but yes, they are so flexible that they will seek out and herniate from the smallest hole in your tyre that a butyl tube would bridge. You will hear a loud crack then an obscene farting whistling noise as the air runs out.
I was messing around with a latex tube recently when my cat took a swipe at it; her claw went straight though it!
But the ride quality and the amazing noise make them worthwhile.
Posted : 05/10/2017 9:40 am
I'd use a normal tube for that, no worries. I used to use 1.5" tubes in 2.2" tyres all the time.
Posted : 05/10/2017 10:19 am
Not sure I get you, or are you not talking about latex tubes at all?
Posted : 05/10/2017 10:36 am
