How often to replac...
[Closed] How often to replace Shimano Hollowtech cranks to avoid catastrophic failure?
my experience, (31 years mtb, and have worked in 5 different shops) some people can break anything
Speaking of which, whatever happened to @MidlandTrailquestsGraham?
Posted : 03/04/2018 2:09 pm
I bought some SLX cranks in 09. They've been on 150mm trail bike, a couple of hardtails and a rigid SS. No snappage happened. They will of covered thousands of miles. I did manage to bend the spider through a rock strike though.
Now retired due to worn splines otherwise they'd still be in use.
I've never seen or heard of a crank snap other than a couple on the net.
Posted : 03/04/2018 2:23 pm
Lol mtqg, yeah he wore a few bits out eh.
Anyway, back to business.
i used some specialized cranks in 1996, they were fine.
my mate used some specialized cranks in 2014, they broke.
zomg, 50% of all the specialized cranks ive seen have broken!!
that is an actual fact.
would it stop me from buying specialized cranks do you think?
roflcopters . . . .
Posted : 03/04/2018 4:01 pm
I have done a statistical analysis based on assumed values for the high and low cycles. It gets a bit technical but the numbers work out to be every 11th Thursday.
Posted : 03/04/2018 4:25 pm
is that when they will snap? Or when you can safely ride them?
does it count if you miss a ride that day for some other reason?
or will they only snap every 11th Thursday if it’s a full moon?
Posted : 03/04/2018 5:11 pm
What happens if you have given up snapping cranks for Lent?
Posted : 03/04/2018 5:16 pm
I've some from 1986 that are still fine so we now only have a failure rate of 33.3333333333333333333333333%
Posted : 03/04/2018 5:20 pm
I knackered the taper in my Spesh cranks in 2000, so back to 50% failure rate.
Posted : 03/04/2018 5:37 pm
Ride them!! don't be so silly, they are accidents waiting to happen.
Posted : 03/04/2018 5:44 pm
Page 2 / 2
