How do you know whi...
[Closed] How do you know which headset cartridge bearings are compatible ?
I need to order some headset cartridge bearings.ย How do know which headset cartridge bearings are compatible with the bike and whether they will fit ?
I know the last ones I bought were these:
https://winstanleysbikes.co.uk/hope-headset-cartridge-bearing
But there is no details on what size or spec they are or anything.
Whenever I have looked at the actual headset bearings, there is no details on them stating what size they are.
Posted : 03/05/2018 1:28 pm
 Yak
Measure the old ones. Then enter the dims into an online bearing shop bearing finder thingy. Eg simply bearings
Or look up the manufacturers spec sheets.
Posted : 03/05/2018 1:31 pm
Measure; inner diameter, outer diameter, height, inside angle, outside angle.
Posted : 03/05/2018 1:49 pm
there really should be markings somewhere on the bearings - usually on the shield.ย  Might be quite faint
Posted : 03/05/2018 2:35 pm
