How do you get dirt...
[Closed] How do you get dirty old chain oil off the carpet?
There's a small black splodge of old black chain oil on my carpet, not sure if it's come off a bike or my shoe, but I need to clean it off, please? ๐Ÿ˜ณ
Posted : 14/11/2011 8:16 pm
 ton
clean oil, something like olive oil or veg oil.
then hot soapy water.
Posted : 14/11/2011 8:22 pm
wd40, serious it works, then rucks of spoapy hot water
Posted : 14/11/2011 8:23 pm
I have lots to get off my carpet if I want any deposit back!
Cheers chaps
Posted : 14/11/2011 8:37 pm
It's like a yellow pages ad this. "It's just possible you could save my life"
One of WD40's main ingredients is stoddart solvent- basically, dry cleaning fluid. Course it also contains a load of light oil but you can sometimes exchange a black horrible oil stain for a light one.
Posted : 14/11/2011 8:45 pm
Buy a rug?
Posted : 14/11/2011 8:47 pm
๐Ÿ˜€ Unfortunately I've got neither WD40 nor kitchen oil (just finished the ev olive oil on a salad).
Posted : 14/11/2011 8:48 pm
Buy a rug?
Top step of me very steep stairs, I predict a visit to A&E.
Posted : 14/11/2011 8:52 pm
I've got some dry cleaning fluid, could I use that then??
A loved ones favourite garment will attract any oil on the carpet if briefly rubbed across it
Posted : 14/11/2011 8:57 pm
Chain degreaser then soak up with kitchen towel...
Posted : 14/11/2011 9:00 pm
white spirit. the end. at least, in this flat...
Posted : 14/11/2011 9:26 pm
What? the end of the carpet or the black oily mark?
Posted : 14/11/2011 9:28 pm
A carpet mousse foam spray from pound shop always does it for me.
Much harder to remove coffee or red wine.
You can buy a very decent refurbished VAX cleaner vac for less than 100 notes on fleabay.
Posted : 14/11/2011 9:29 pm
Have something delivered or invite some mormons around then accuse them of depositing oil on your carpet.
Posted : 14/11/2011 9:31 pm
isn't there something about using an absorbent material and an iron or is that for something else? Failing that, you could use a credit card.
Posted : 14/11/2011 9:32 pm
fairy liquid has always worked for me. Even when I decided to take the little grub screw out of a romic shock that allowed blue oil to spert out of it as it it was an ahem.. you can imagine
Posted : 14/11/2011 9:34 pm
no! the carpet is still "beige with a pink hue" according to my better half. ๐Ÿ˜‰
Posted : 14/11/2011 9:37 pm
Use red wine
๐Ÿ˜‰
Posted : 14/11/2011 9:50 pm
 hels
Motorbike brake and chain cleaning stuff. Sprays on nicely.
Posted : 14/11/2011 10:03 pm
I figured out how to do this when I was a kid - saved my neck many a time. Jab the straw from a can of WD40 into the pile, and pack some bog paper around the top. Squirt, and the WD40 goes into the carpet, dissolves the oil and the tissue paper soaks it up. Works a treat - you can then use soapy water or something simple to get rid of the WD40.
Posted : 14/11/2011 10:43 pm
Baby wipes - Seriously they remove everything.
GT85 is also a good substitute for WD40
Posted : 14/11/2011 11:44 pm
would suggest you to ask experts @ http://www.goldriverfloors.com/
Posted : 22/10/2012 12:29 pm
 DrP
A little tip for you all:
It's better to have a tiny mark of crayon on your carpet, that a huge 'scab' of melted wool the shape in the shape of an iron....
Just FYI...
DrP
Posted : 22/10/2012 12:31 pm
i clean carpets for aliving, be very careful of the chemical products you put on the spot, ive seen no end of times people putting vanish on a spot only to bleach their carpet,always try warm water and a small bit of fairy liquid first, not every carpet reacts well to chemical sprays, usually if your carpet was scotchguarded in the first place warm water will do the job
Posted : 22/10/2012 1:05 pm
Swarfega works amazingly well in this situation.....
Posted : 22/10/2012 1:14 pm
Wool doesn't melt. HTH.
Posted : 22/10/2012 2:42 pm
neat fairy liquid is ace. It removed the contents of my romic shock from a beige carpet
Posted : 22/10/2012 2:44 pm
FFS guys, 11month old thread ressurected by someone registered today and recommending a flooring company in the US
MODS to the forum - Bensmoa a spammer or what?
Posted : 22/10/2012 2:59 pm
I took the easy option a few years ago when i dribbled fork oil on my biscuit coloured carpets in the living room and through the hallway as i absentmindedly wandered through the house with my forks upside down, i lifted the carpets and threw them in my neighbours skip, now got bare floorboards which are far easier to clean but admittingly a bit drafty and one of these days i might get round to sanding them down and filling in the cracks then varnishing, but then again i doubt it as i've far better things to do with my time and anyway...i've lived wi them like that for 4 yrs and if i do spill anything it's no big deal.
Living the single dream since 2004 ๐Ÿ˜€
Posted : 22/10/2012 3:58 pm
Do a search for Inhibasol solvent cleaner, it evaporates leaving no residue.
Posted : 22/10/2012 5:10 pm
GT85 is the bizness.
Posted : 22/10/2012 5:36 pm
