How do identify whi...
[Closed] How do identify which version of the xt chainset that I have
I need to replace the middle chain ring on my xtchainset. I have had a look on crc and mine looks like the 770. The middle chainring comes with a note that says it only works with this model and none of the others.
Is there a way to work out which version I have, before I shellnout for the new one?
Posted : 01/07/2012 7:51 pm
 mboy
Model number will be stamped somewhere on the crank, usually on the back of the arms, by the pedal thread.
Posted : 01/07/2012 8:03 pm
I'd not read too much into that...
Posted : 01/07/2012 8:05 pm
Cheers, I'll have another look on the arms.
Posted : 01/07/2012 9:19 pm
I would.
Current 10 speed XT middle ring won't fit on a lot of cranksets...
Posted : 01/07/2012 9:38 pm
One of the XT chainsets from a few years ago (760 or 770) had a different internal diameter middle ring so it could make quite a difference getting the right one.
Posted : 01/07/2012 10:25 pm
Wasn't it fitting the old 760 XT rings onto Deore that was the issue ?
Either way I swapped rings around & had no issues. Doubt many folk with Deore cranks fitted XT rings anyway.
Posted : 01/07/2012 11:05 pm
xt m770 middle chainring (9 & 10 speed) won't fit many other cranks due to the width of the composite part of the chainring, for instance m771 std chainring will fit m770 & m771 cranks but m770 composite chainring won't fit m771 crank - as mboy says ref number will be stamped on inside of crank near pedal thread - just make sure you read off the drive side crank to be sure.
Posted : 02/07/2012 12:39 am
