how can you tell if...
[Closed] how can you tell if a set of brakes are IS mount and a post mount? cheers
Posted : 09/06/2011 3:56 pm
note the holes where the bolts go on the caliper
Post mount
everything else is IS
Posted : 09/06/2011 3:59 pm
Save the picture to your computer, as this regularly confuses me ๐Ÿ˜•
Posted : 09/06/2011 4:00 pm
This caliper is IS mount. It screws straight to the fork or frame
This one has the holes at a different angle to the one above and needs an adaptor to attach to the frame
Hope that helps ๐Ÿ™‚
Posted : 09/06/2011 4:03 pm
Is there a benefit of one over the other?
cheers ๐Ÿ™‚
Rob, post mount is easier to set up, IS mount is a bit lighter (And I think looks neater)
Posted : 09/06/2011 4:04 pm
they are interchangeable if you get the correct adaptor for the fork/frame.
Posted : 09/06/2011 4:21 pm
 5lab
so what does boxxer mount look like?
Posted : 09/06/2011 4:29 pm
unless the frame is post mount....
Boxxer mount is similar to IS I think (sideways bolted) but possibly different dimensions
Posted : 09/06/2011 4:33 pm
Also may hopefully be helpful to add:
1. Most current brake calipers out there are post mount.
2. Post mount caliper onto post mount fork seems to be the trend/most common.
3. Post mount caliper onto IS fork is a fairly standard adaptor.
4. Most frames have IS mount at the rear and the adaptor to post mount caliper is usually included with the brakes.
Hope that helps
Posted : 09/06/2011 4:38 pm
