How can I convert m...
[Closed] How can I convert my 2015 (oem) RS revelation rct3 from 140mm to 150mm?
[#6588956]
Just wondering if I can convert my revs to 150mm travel. Is it a spacer addition/removal, something more in depth or not possible at all?
Cheers.
Posted : 28/10/2014 9:58 am
Should be possible, but needs a new air shaft.
Not the same as the earlier RS's where you could add/remove spacers.
Posted : 28/10/2014 10:03 am
 sv
Somebody else on here yesterday wanted to go the other way - possibly Northwind. Might be worth searching the forum and seeing if a swap is possible?
Posted : 28/10/2014 10:05 am
yeah new air shaft, got mine from my lbs
Posted : 28/10/2014 10:36 am
Soooooo, finally getting round to doing this.
Anyone know where these are readily available by any chance? I spoke to loco earlier (and was very helpful) but he hasn't got one and none in stock with the supplier until the end of April....
Posted : 31/03/2015 3:35 pm
Amazon of all places seemed to have Pike ones in stock, worth a try for Revs.
Posted : 31/03/2015 4:21 pm
The one I found on amazon stated 'usually delivered within 1 - 3 months', I'd rather order off loco if that's the case...
Posted : 31/03/2015 6:31 pm
