Horizontal dropouts...
[Closed] Horizontal dropouts and chain tugs with gear hangers - Tell me more!
Appreciate this may only appeal to a small demographic!
I can see that in use they might be a PITA when you need to remove a wheel but generally do they work okay?
Posted : 21/08/2012 1:35 pm
People say the Roadrat setup is a PITA. It really isn't.
Posted : 21/08/2012 1:37 pm
 trb
I have a slidey drop out inbred, and it works just lovely with either gears or SS. In fact I swapped from 1x9 gears to SS last week in about 20 minutes.
Posted : 21/08/2012 1:38 pm
2011 TransAm is a ****tard to swapout the rear wheel. However once in - the 10mm axel means it does soak up really rocky trails like no other hardtail i've ridden.
worth noting the 2012 transam has a new wheel/frame interface system
Posted : 21/08/2012 1:48 pm
Thanks guys ๐Ÿ™‚
Posted : 21/08/2012 3:11 pm
..and if you are running gears you don't really need the chain tugs (I don't on my inbred).
Posted : 21/08/2012 3:41 pm
you prolly don't develop enough torque...
Posted : 21/08/2012 7:08 pm
http://www.chainreactioncycles.com/Models.aspx?ModelID=20322
cunning chain tug and hanger in one
Posted : 21/08/2012 7:13 pm
If its a Shimano hub, swap the axle for a solid nutted one & the tugs aren't needed.
In fact any hub that can swap to nutted or bolted should suffice.
A QR could not harness the awesome power of the Takisawa.
Posted : 21/08/2012 7:35 pm
