Hope Tech X2's........
[Closed] Hope Tech X2's......advice with problems and potential bleed....
Chaps,
Got around to building new bike yest at last (after 3 month wait!!)....
New set of Tech X2's......took out of box blah blah....
When fitting rear, the lever body was hanging for a little while....when I came to mounting to bars there was quite a bit of fluid around the reservoir cap and lever body.......as you can probably guess on completion the lever is super soft with no feel. I've centred the pads/caliper and played around with the bit point control etc....
What I don't understand is how the res lost the fluid?...the cap was tight etc......is there some sort of purge/over-flow hole?
If I'm now to bleed the brake and shorten the hose.....is it a standard replaceable olive job?
Any suggestions appreciated!!
Posted : 21/04/2009 11:09 am
Go to the hope website and watch the video about bleeding brakes that have a tech lever.
Shouldnt be leaking fluid from the body unless the caps are not done up tight or the hose is loose...
Posted : 21/04/2009 11:27 am
Very easy to shorten hose.If you remove hose from lever end you might not even need to bleed them! Done mine a few weeks ago.Once you remove sleeve theres a small slotted olive that you have to prise apart with small screwdriver.This is reuseable.Had no problems with Hope so far! Try talking to Hope.Sounds like you have a leak somewhere?
Posted : 21/04/2009 12:04 pm
