Hope Tech 3 lever r...
[Closed] Hope Tech 3 lever rebuild instructions?
Does anyone have a link to some? I've removed the lever and it looks like I need to remove a small torx like screw to be able to remove the piston and replace the seals.
There are great guides online for the older levers which I've serviced before but this tech 3 is different.
Cheers.
Posted : 24/07/2017 12:55 pm
I've not touched mine yet but the exploded parts diagram on the Hope Tech site probably tells you what you need to know... looks like the screw secures the piston stop plate - which gives you access to the piston and seals, etc.
Posted : 24/07/2017 1:30 pm
Thanks I'll check that out. It's a security torx so just picking up some bits now.
Posted : 24/07/2017 1:43 pm
