Hope reservoir cap ...
[Closed] Hope reservoir cap screws overtightened, options?
[#10412827]
So....
Got a bargain tech3 lever on eBay to pair with the left one I bought ages ago
Turns out not such a bargain, reservoir cap screws are immovable.
The torx are almost rounded I've hacksawed a slot for a flathead but no joy.
I'm picking up an impact driver (the hit with a hammer type) tomorrow
I can try & saw thru the cap but not sure my lbs will have a replacement & probably a seal b4 a ride on Wednesday.
So chuck it in the freezer, would that help?, Heat ?
Posted : 30/12/2018 10:36 pm
Easy out? A very small one?
Posted : 30/12/2018 10:40 pm
Do you know what everything's made of? If the screws are steel and the threads alu then maybe heat would help loosen the threads (though if the cap is also alu it might actually put more pressure on the screw when it expands). Try heat and then if no good then try cold, maybe that 'cycle' will free something up anyway.
or drill off the heads so you can just lift off the cap, then hope that there's enough "stud" to get a grip on.
I guess it's too late to send it back 🙁
Posted : 30/12/2018 10:54 pm
Might have to sacrifice the top cap, but can you file flats on the sides to get mole grips onto them?
Posted : 30/12/2018 11:20 pm
anywhere near Bristol/Mendips as I'm sure I have some spare tech 3 caps and seals somewhere.
Has anyone else found the top caps are sometimes very hard to remove on new ones from the factory?
Posted : 31/12/2018 12:20 am
Best of luck trying to drill a pilot hole in a stainless bolt that small before you even find an easy out to fit in there.
Best option is drill the head off remove the cap and get some grips on what's left of the stud.
Posted : 31/12/2018 12:27 am
Best option is drill the head off remove the cap and get some grips on what’s left of the stud.
^this. Though he prepared to have to replace the top cap too. The bolts are diddy, so easy for the drill bit to slip.
Posted : 31/12/2018 10:26 am
How about fitting the lever and turning the bike/brakes upside down and bleeding from the caliper until you can get a new top cap and screws.
Posted : 31/12/2018 10:48 am
Impact driver......noooo
You will probably end up distorting the whole body of the reservoir.
Posted : 31/12/2018 2:34 pm
Only if you do it wrong.
Great tools if used right.
I certainly wouldn't be doing it on a bike and it would require a home made support jig for the lever body and a vice. But it would save me paying to replace parts.
I think if I'd got as far as the op has though I'd follow ssstus advice.....
Posted : 31/12/2018 3:26 pm
Could be worth contacting Hope before going any further. I had an issue with a C2 lever BITD, can't remember what exactly but something was stuck or stripped. They told me to send it to them and they did a rebuild for a nominal sum. Always worth asking, even if it's just "what would Hope do...?"
Posted : 31/12/2018 4:29 pm
Its the update youve all been waiting for...........
with the help of £14 impact driver from screwfix both screws came away!
brakes bled, bike ready
hopefully get 6 hours sleep b4 I have to leave for Afan tomorrow!
Posted : 02/01/2019 12:27 am
Very under rated those impact drivers.
Love mine would replace in a heart beat if it broke.
Posted : 02/01/2019 8:35 am
Nice job OP 🙂
Posted : 02/01/2019 8:43 am
