Huhhh???
Posted : 14/11/2010 2:05 pm
Posted : 14/11/2010 2:38 pm
that sucks. thanks for the info
is it possible to fit a 15mm maxle to the rockshox 2010 team revs if they come with a 20mm axel?
(i have googled but not found anything, does this mean im to stick with Pro2)
Posted : 14/11/2010 2:57 pm
you can use a Pro2 Evo hub, other than that you'd need some different lowers although i don't think you can have a 15mm rev?
Posted : 14/11/2010 3:00 pm
They don't say whether Pro3 hubs can be converted to 12mm bolt thru? anyone know?
Posted : 14/11/2010 3:24 pm
Both wheels are QR and the fronts are supplied with a 15mm conversion and the rear is convertable to 10mm boltย throughย (NOTE: this hub cannot be converted to 20mm).
Same page as linked above, there a lightweight racer wheelset, not you classic DH hub really, & 10mm rear should be plenty stiff enuff.
Posted : 14/11/2010 7:00 pm
The Pro3 AM4 CAN be converted to 20mm
The Pro3 XC3 CONNOT be converted to 20mm
Posted : 14/11/2010 7:18 pm
The pro3 am4 has pro 2 internals hence being able to convert to 20 or 15qr
Posted : 14/11/2010 7:46 pm
