WhenI was running my Hope Pro II hub with a 20mm axel on both my Pikes & Van 36's there was no free play of the hub about the axel.
However since the wheels have been swapped to a bike with a normal QR up front, there's a bit of play in the hub, you can feel it when you apply the front brake and "wiggle" the wheel with your hand.
I've changed the o-rings on the QR adapters but it hasn't got any better.
Is it rebuild time?
If there was no play with the 20 mm axle then there should be none with the QR.
Is it all assembled properly with no endfloat of the wheel on the axle? the qr should pull it all together.
Tried it all for end float (I assume that's the hub moving side to side within the QR) and there's definate play in the hub.
New bearings me thinks
Its not your brake pads moving is it? Sometimes that can feel like bearing play.
Bikechain, I tried my mates Hope hoop in place of mine today and there's no play
Sorted, two new bearing installed and all wobbly bits gone.
It's fair to say the ones that came out were a bit on the rusty side.
Hope still deny this issue excists.its the bearings that are not seated properly. A gentle tap job done
LOL different "issue" knott4me, his bearings had play in them, this isn't the "my 20mm to QR adapters won't fit in my forks".
