Hope PRO II from QR...
[Closed] Hope PRO II from QR to bolt - will it make the rear end stiffer?
So I have ridden the hope pro II quite happily for the last few years and it has been very good in the QR format. I really wanted to make the back end a little stiffer to match the maxle on front end will converting the Hope Pro II to a bolt through do the job and is there a kit for it available from Hope?
Any thoughts would be welcome.
Posted : 11/06/2010 5:16 pm
 jim
What bike?
Posted : 11/06/2010 5:17 pm
Sorry should have mentioned.
It's on a felt redemption 3, dhx air 5, 6+ inches travel front and rear. I'm 100+kg with little finess on the bike.
Posted : 11/06/2010 5:20 pm
 RicB
Made a big difference to my old model 575, mainly when mashing the pedals. I don't go round corners fast enough to notice it there!
Hope do a bolt [b]up[/b] and bolt [b]through[/b] make sure you pick the right one.
I think Superpoo components do an axle for the bolt through, I just used the bolt-up.
Posted : 11/06/2010 5:26 pm
RicB
sadly I have to ask this question...
whats the difference between the two you've just mentioned
DM
Posted : 11/06/2010 5:32 pm
 RicB
Bolt up is held in place by 2 hex bolts so you need a 6mm Allen key to take the wheel out. The kit comes with 2 bolts.
bolt through uses a big qr (10mm dia I think) so removing the wheel is quicker. Don't think the Hope kit comes with an axle
bolt up is slightly lighter iirc
Posted : 11/06/2010 11:00 pm
you will want 1 of these
http://superstar.tibolts.co.uk/product_info.php?cPath=32&products_id=287
and one of these
http://www.chainreactioncycles.com/Models.aspx?ModelID=18761
and yes stiffened up the back end on my kona dawg
Posted : 11/06/2010 11:12 pm
