Hope pro 4 hoops. X...
[Closed] Hope pro 4 hoops. X12
[#9477513]
Hi I've just built up my new bike and it's x12 142 rear axle. Got some hope pro 4 hubs. That come with 12mm conversation but the disk is only a mmm from fraim. Is there a difference between 12mm and x12 conversation. Thanks
Posted : 06/08/2017 10:40 am
What size of rotor? Could be you'll need to go smaller.
Posted : 06/08/2017 10:51 am
The 12mm kit is fine for x12. What is the max disc size for the frame and what size disc?
Posted : 06/08/2017 10:57 am
Hope do list a conversion kit as "12mm" which is the 135 x 12mm. If you recently bought Hope Pro 4 Hoops, they'd come with 135mm QR and 142 x 12 adaptors.
Got a photo of the disc/frame?
Posted : 06/08/2017 11:18 am
Dont think the spacers aren't symmetrical. My pro 2 were different colours and need to go on a specific way, maybe try swapping them.
Posted : 06/08/2017 11:23 am
It says 180. I've fitted a hope floating I'm just trying to get a pic listed
Posted : 06/08/2017 11:26 am
Yea silver on drive and black on non drive.
Posted : 06/08/2017 11:27 am
https://1drv.ms/i/s!Ajx3h-0uDSjIg8sVNQ8f1szoi6gT5g
Posted : 06/08/2017 11:39 am
Thats pretty normal. The rivets on Hope disks always run quite close to the post mounts on forks.
Posted : 06/08/2017 12:02 pm
Looks fairly normal. Hope floaters are quite a bit wider than normal discs, and hope hubs are a sneak wider than many others too - and given 99% of hope floating discs are probably running on hope hubs.... We actually had to change our post mount design to accommodate them with enough room (more than you have), even though our original post mounts were within the design spec for Shimano & SRAM brakes.
Posted : 06/08/2017 12:04 pm
Not sure if a 1 or 2 mm shim between hub and frame woulfbe a good idea. Just bony like the idea of it rubbing on the carbon.
Posted : 06/08/2017 3:49 pm
