Hope Pro 2 Evo ques...
[Closed] Hope Pro 2 Evo question.
[#3751770]
So I have just got some Fox float 32's with a 15mm axle, before I had pikes with the 20mm adaptors for the hub.
My question is can you pull the qr spacers out of the adaptors I got with the hubs to make them 15mm?
So from this; http://www.chainreactioncycles.com/Models.aspx?ModelID=10238
to this; http://www.chainreactioncycles.com/Models.aspx?ModelID=30152
Posted : 07/03/2012 11:02 pm
Yes I think so. THe Evo front is the same as the rear IIRC. They did something to the rear axle which was the reason for the rebranding.
Look for exploded diagrams on hopes website.
Posted : 07/03/2012 11:18 pm
Yeah You can. Thats the beauty of Hopes
Posted : 07/03/2012 11:31 pm
Cheers guys I thought you could but when I tried it earlier they were really tight so thought I may have made up the idea, will try again the morn.
Posted : 07/03/2012 11:37 pm
I'm not sure because I just bought two new evo wheels, and theres no way the 20mm adapter will fit in the hole. I use the 15, which works fine, but the 20 seems a few MM too big.
Posted : 08/03/2012 12:49 pm
Should have said when I bought my wheels they came with with the smaller adaptors (9mm/15mm I think) and I bought the 20mm ones separately to use with my pikes.
Posted : 08/03/2012 5:36 pm
CBruce - I could be wrong but I think the adaptors dont cross over from ProII to Evo Pro II, there's a seperate item on CRC called the 'Evo Adaptor'.
My new Flows came with Evos and a 20mm with them, but for the rear I've had to purchase the 'evo' adaptor.
Hope this helps.
Posted : 08/03/2012 6:10 pm
