b u m p
Posted : 27/02/2010 5:12 pm
Monkey, look at [url=
]Hope tech drawing[/url] - this is of an xc mono front hub, but the principle will be the same.
You can buy the bearing support tools from [url= http://www.chainreactioncycles.com/SearchResults.aspx?Search=hope+bearing+support ]CRC[/url].
Seemples!
Posted : 27/02/2010 5:42 pm
Leave it on when you tap the axle through, that side will just fall off when the axle passes through. Rest the remaining bearing attached to the axle in a vice jaw and tap it through, job done.
Posted : 27/02/2010 7:46 pm
coatesy - doh - yea - that makes sense - ta very ๐
Posted : 27/02/2010 7:58 pm
