Hope mini brakes - ...
[Closed] Hope mini brakes - how do you tell the size?
On the old Hope Mini brakes, how do you tell which caliper fits which rotor?
Looking to use one with a 140mm or 160mm rotor. Which caliper should I be looking for?
Ta ๐Ÿ™‚
Posted : 27/01/2017 1:59 pm
I think this is the guide to caliper sizes
1 - Hopes own standard, designed for the original line of Hope brake adaptors
2 - Rear calliper for frames without disc mounts. Used to use a shortened axle
3 - International Standard, 51mm spacing. Front 185mm rotor, rear 165mm
4 - Might of been 48mm Marzocchi Standard
5 - International Standard, 51mm spacing. Front 165mm rotor, rear 145mm
6 - Boxxer Mount 205mm Rotor
8 - International Standard, 51mm spacing. 205mm rotor front
9 - Manitou/Post Mount. Early models were 71mm I think, then Manitou changed it around 2000 to the current 74mm standard.
Posted : 27/01/2017 2:26 pm
Just nipped out to check on my bike, and been beaten to it. I can, however, recommend running Hope C2 rotors (non Wavey) on them as they hardly ever squeal like the waveys were reknown for.
Posted : 27/01/2017 2:31 pm
Thanks both
Posted : 29/01/2017 4:29 pm
