Hope Hub - How to t...
[Closed] Hope Hub - How to tell...
[#2621337]
How do you know if your bearings need replacing?
I'm in the process of replacing the cassette, its off the freehub.
I tried turning the bit where the QR skewer goes (not the actual skewer) and I can barely turn it by hand. The freehub also seems to be not very free, although it still clicks very loudly when turned.
Posted : 01/04/2011 2:34 pm
It all sounds goosed. If it is reluctant to spin or you can't do it readily get them changed - either LBS OR buy the drifts/bearings and DIY. If you go to the tech bit of www.hopetech.com there's a good video and drawings showing you how.
Posted : 01/04/2011 3:16 pm
Wheel - wobbles side to side
Freewheel - doesn't freewheel
Posted : 01/04/2011 3:27 pm
Stiff bearings = replacement time. Pretty easy to do the freehub (remember the circlip on XCs!), do the main hub body at the same time.
Posted : 01/04/2011 3:59 pm
A great way to check wheel bearings is to use the resonance qualities of the frame. Making sure that there's no binding from brakes, and with the chain removed for the rear, just give the wheel a good spin and place your ear against the top tube (or down tube if you've flipped the bike over).
Posted : 01/04/2011 5:29 pm
Cheers foxyrider, that guide is perfect. Bearings removed and everything cleaned, now where did I put the bearings! The old bearings feel rather rough and it was extremely dirty and one was damn hard to get out!
Three Fish, I'll try that on the front... Next week!
Posted : 01/04/2011 5:59 pm
oh bearings bearings...(: , took my Pro 2 to LBS due to bit of play, thought it might be a set or 2 of bearings, ended up being all 5 sets + soem broken pawl springs, whole lot was arusty stiff mess---all comes from riding through deep puddles / stream crossings in mid Wales I reckon as there`s no way to dry them out
Posted : 01/04/2011 6:37 pm
Great Milkie - glad it helped 🙂
Posted : 01/04/2011 6:59 pm
Finally had some time spare to fit the bearings... All fitted, new chain, cassette & crankset..
I now have a slight problem... When in the middle of the cassette, two gears feel very rough, all the others feel fine (feels like a dirty chain/BB/worn chainring)... Any thoughts on what's causing this!?
Posted : 06/04/2011 10:47 am
Which two? Probably just indexing, although you should, if appropriate, make sure that the individual sprockets aren't fitted back to front.
Posted : 06/04/2011 11:38 am
I think its 4th & 5th gears down, the ones on the main spider arm. I'll give indexing a go, but I thought they were bang on.
Posted : 06/04/2011 12:04 pm
