I am after a 27.5" rear boost Hope Fortus 30 wheel in blue flavour but can't find one in stock anywhere.
Does anyone know if such an elusive beast still exists and where I might find one?
Just a Blue 148mm rear hub will be a great help.
I will be muchly grateful for any pointers.
Interestingly I found out the other day that the fortus 30 is actually heavier by some way than the 35 and ridiculously more heavy than the 28.
But to answer your question try evo cycles, I got a set of 35's the other day.
Just in case you didn't realise the Fortus 30 is the one with all the extra material in which is intended for DH riding.
There are much better, lighter rims with the same width for regular riding. Unless you really need the extra strength.
Depending what freehub you want, sprockets cycles have blue 30s in Shimano fit
Thanks for the input, guys.
I'll check out Evo and Sprockets.:-)
