Hope brake pad clip...
Hope brake pad clips
11 Users
2 Reactions
How is it that i always lose them when taking the pads out?
Even if i put them in a safe place away from where im working (along with the brake pads and the pad bolt) one will still go missing or i will drop one during fitting and not be able to find it on the garage floor!
To combat this i bought 6-8 pad clips at the start of this year, 4 of my bikes have Hope brakes and guess what, all those spare clips are now gone gggrrr!!!
They are only 40 pence each to buy but then its another £3 to £5 for postage for 6 to 8 pad clips that are smaller and lighter than a 2 pence coin!!
Rant over and back to the garage floor to find the missing clip!!!!
Posted : 02/12/2023 3:01 pm
Get a magnet!
I butchered an old iPad cover and have one of the two magnetic strips stuck to my work stand for exactly these problems. Alternatively lidl/aldi sell wee magnetic bowls that are also very handy (and can be used on car bodywork). Can also be salvaged from old speakers.
Posted : 02/12/2023 3:04 pm
You can use a bit of fine wire in its place.  thread it thru and twist it ( if you mean the ones that go thru the pin)
Posted : 02/12/2023 3:05 pm
Get a magnet!
Got one of those and always forget to use it and it wont help when i drop the clip during fitting
Cant possibly do that, it would mess with my OCD on everything matching and using the proper parts on my bikes!
If i cant find the one on the garage floor ill rob one off one of the other bikes (summer bike, just hope i dont drop that one too!) until i need to place a larger online order and then ill get some more then
Posted : 02/12/2023 3:11 pm
20231202_151428
Posted : 02/12/2023 3:15 pm
As said ive got one of those, i will forget to use it or ill just drop the pin whilst fitting and lose it that way!
Thinking i might get some magnetic strip tape and attach it to the bottom of a broom and then sweep the garage floor for the pin!
Posted : 02/12/2023 3:26 pm
I always just remove them and rely on the bolt instead.
Posted : 02/12/2023 3:34 pm
People use those things?
Posted : 02/12/2023 3:51 pm
Lost one outside whilst cleaning the bike. Didn't notice for a few days, yet managed to locate it almost immediately. Had one ping off in the kitchen whilst servicing- took bloody hours to find!
Still not quite as infuriating as losing the 3/32" bb from the detent in the talas selector, only to discover the kitchen floor was littered with similarly sized spherical cake decorations.. (I gave up).
Posted : 02/12/2023 6:52 pm
tjagain and tjagain reacted
I've got lockwire in mine.
Decided the clip was too much faff for nighttime pad changes at the puffer, and haven't found a good reason to put the clips back in since.
Posted : 02/12/2023 7:32 pm
I always try to fit the clip when I put new pads in - always fail and just bin it - I can never figure out how they work
Posted : 02/12/2023 7:45 pm
I always use them, they are a faff. A bit of tying wire would work well.
Posted : 02/12/2023 7:57 pm
there is a knack to the clips - you put them in vertically and do a 90 degree twist and they just go on.  Same in reverse to get them off.  got to be the right way.  simply once you have the knack
Posted : 02/12/2023 7:59 pm
God I hate those things, infuriating fiddly little things in poor light. I never use them, never had a pad retaining bolt come undone, even when Hope used an o-ring instead of a thread on M4 calipers I never used them, I've got some anodised alloy wire in various colours from an arts n crafts store in Manchester, a perfect alternative.
Posted : 02/12/2023 10:22 pm
