high five zero..?
[Closed] high five zero..?
25 Users
just got some through with my crc order..whats it like?
Posted : 01/07/2011 11:54 am
Try it and see, it won't kill you.
Posted : 01/07/2011 11:55 am
it won't kill you.
It might do, it's just nasty artifical sweeteners.
Posted : 01/07/2011 11:57 am
I agree with finbar... made me ill for a week after about 2 months usage...
Posted : 01/07/2011 11:59 am
No aspartame in it..
Edit: ah, reference to aspartame removed.
Ingredients: Citric Acid, Sodium Bicarbonate, Sweeteners (Sorbitol, Sucralose), Malic Acid, Tri Sodium Citrate, Potassium Citrate, Magnesium Carbonate, Flavouring, Colour (Riboflavin), Maltodextrin, Calcium Carbonate, Polyethylene Glycol, Vitamin C, Green Tea Extract.
Doesn't look too bad?
I use it and have felt fine. I used to use Nuun but the Zero stuff is cheaper and seems to do the same thing?
Can't honestly say if it helps with my hydration but i certainly cramp less than i used to so i'm happy to keep using it.
Posted : 01/07/2011 12:01 pm
Agreed, looks alright to me.
I like it, use it to hydrate myself before a race generally.
Posted : 01/07/2011 12:02 pm
Got a bottle of those tabs a couple of weeks ago. They taste nice (The citrus ones) but IMO they made me get cramp! The only times i've gotten cramp whilst riding, was when i was using these.
I'm going to use the rest of them up, and i don't think i'll buy again. Going to go back to just drinking water. I MAY try Nuun to see what they're like. For a couple of quid, they're cheap enough to throw away if i didn't like them. Or, i'll feed them to the seaguls 😀
Posted : 01/07/2011 12:05 pm
Yeah, i thought the ingredients were worse than they are 'til i checked. Still wouldn't drink it though.
Posted : 01/07/2011 12:07 pm
just asking as i generally just use water unless im doing a long ride 3+hrs.
usually use torq but interested in others experience.
i'll give it a go when im next out.
Posted : 01/07/2011 12:17 pm
Nuun gives me mega-burps, High-5 don't & are cheaper so I'd buy them again - neither stopped me getting cramps though.
Am about to try Tesco's own version of Berocca tablets instead as they have more vitamins/ minerals / electrolytes & work out cheaper per tablet.
pbw...i'll look into them, what are they called? linky?
Posted : 01/07/2011 12:19 pm
Too much sorbitol can give you the Ertha Kitts
Posted : 01/07/2011 12:35 pm
There's one that's fizzy and tastes like cheap red bull. Might be the caffine one?
The fizz wasn't pleasant when riding and not expecting it (was ok after a bit) and I found that really left a bad aftertaste. The other ones I've tried were better.
Posted : 01/07/2011 12:39 pm
i use the berry zero during playing squash and for long rides, tastes ok and is cheaper than off the shelf electrolyte drinks.
Posted : 01/07/2011 12:41 pm
I've been using them for a while now, used to use elete electrolyte but always ended up putting too much in and made water taste like sea water.
Zero taste nice,(orange and cherry my fav) are easy to use and seem to work for me. (CRC marathons, 24hr racing etc) just check instructions for how many tabs per bottle. Some use 1 some use 2. (caffeine berry flavour are two tabs)
Posted : 01/07/2011 12:47 pm
I'm a fan. use 1 berry tab per 750ml bottle, works a treat. used to use energy drinks, but hey're just to sweet and heavy for me.
Posted : 01/07/2011 12:52 pm
Very good for hangovers by all accounts 😕
I'ts fine, especially when it's free.
Posted : 01/07/2011 12:53 pm
great for hangovers...
thats all i used mine for.
Speaks volumes.
Posted : 01/07/2011 1:01 pm
 cp
yep, it's one of the few electrolyte drinks I can stomach at intense workloads.
As noted, the ingredients are better than most.
and as with most sports/electrolyte drinks, a pint when you get in off the lash, and another in the morning and you'll be reet in no time 🙂
Posted : 01/07/2011 1:04 pm
Bear in mind there's no carbs in Zero, so you'll need to get it elsewhere; food or gels or sommat.
Posted : 01/07/2011 1:27 pm
I find it great - use it to stop cramps, works a treat, no side effects. No calories as stated above - good for the likes of me.
Posted : 01/07/2011 1:33 pm
Its pretty wrank i think.
Posted : 01/07/2011 1:44 pm
 Haze
Works for me, and slightly more interesting than water.
Posted : 01/07/2011 7:58 pm
It seemed to stop cramp for me and tasted better than Nuun imo, but I did feel quite painfully constipated after drinking it. Nuun didn't have this effect. Personally I like Elete.
Posted : 01/07/2011 8:03 pm
I've just bought some Rego 😐
Posted : 01/07/2011 8:06 pm
Does the job for me, if you are fit then you should be ok with zero carbs up to 3 hrs
Also good for hangovers as the man said - top tip - neck one tab plus a pint before going to bed
Make sure you have a piss too 🙂
Posted : 01/07/2011 8:08 pm
So? Totally different stuff.
That depends, I couldn't do 3 hours hard on Zero with nothing else, I'd be wrecked, and I'd say I'm reasonably fit.
Posted : 01/07/2011 8:13 pm
According to the tube, it's 65% Carbs (I assume from the maltodextrin) but granted that's not enough in a 4g tablet to meet your carbohydrate needs on a long ride.
Interesting that it causes cramps in some and alleviates it in others. I suspect this may be due to either being low in potassium or sodium or both. I tend to be low in sodium and high in potassium and they seem to work for me. I believe that other electrolytic drinks vary considerably in the ratio of potassium to sodium.
Have been using them for a couple of years now and swear by them when the weathers hot (and for a hangover cure). Having said that I have recently switched over to Torq for longer rides as that meets both my energy and electrolyte needs.
Posted : 02/07/2011 6:22 am
I didnt say you wouldn't be wrecked 🙂 - I'd be a minute away from full bonk meltdown - if I wanted to ride longer than that then would use energy drink and eat
2 hours is probably a more sensible limit
I've deffo shed some timber since I've been using it on shorter rides, although it is not the only factor I'm sure it has helped
Posted : 02/07/2011 6:50 am
