I recently took a set of fox 34 elite forks apart as the CTD knob was sticky. Part of the strip involves removing a shim stack which unfortunately fell out. I am fairly sure that I have them the correct order but need to confirm before I put it back together. Can anyone help me to figure this out. The forks are 140mm 34 fit4 2017 fitted to a scott genius 710.
I have tried silverfish who are the Fox UK reps and they were less than helpful, and would gladly service it for me but not give any technical help.
If anyone can tell me the order that the shims are supposed to go or suggest a place that I can get some technical help it would be much appreciated.
Thanks Mike
Put the 4 digit code in the ridefox site to see exactly what you have
https://www.ridefox.com/fox17/help.php?m=bike
Then check the parts diagrams for the year/model
I finally managed to get in touch with fox who directed me to the same link as you had given bigyan. I am now in a position to get my bike back together.
Thanks for the help.
