Help with making a ...
[Closed] Help with making a 20mm front Axle quick release...
Hello!
Got some secondhand Boxxers with the 20mm Through axle..
As i am taking the front wheel off more... I wanted to get a quick release for it... Is this possible? What do I search for? Sorry! its completely new to me!
Tex
Posted : 01/05/2012 9:37 pm
Nope.
Posted : 01/05/2012 9:39 pm
๐Ÿ™
Posted : 01/05/2012 10:02 pm
Any good?
http://www.pinkbike.com/buysell/903301/
Posted : 01/05/2012 10:26 pm
Hello!
Cheers, but thats to fit a normal axled wheel on... I want to change my current 20mm dia axle to a quick release 20mm dia axel, but not sure what to search for
Posted : 01/05/2012 10:40 pm
Try Hope conversion kits for the axles.
Not sure if there is one component that will fit both the hub and forks. Maxle conversion would be the obvious place to start. Not sure if it exists though.
Posted : 01/05/2012 10:48 pm
The maxle has a threaded insert on one side.. You would to fit something like that before you could use a maxle..
Posted : 01/05/2012 11:57 pm
What Boxxer is it? If it's the older 32mm model then what you need to look into is the QR Maxle from the Boxxer Ride. Don't know if if fits every model but it does fit mine.
Posted : 02/05/2012 12:02 am
I can think of a way to do it but it'd take a couple of hours & some machining. Probably more effort than its worth
Posted : 02/05/2012 7:56 am
