Help with a Special...
[Closed] Help with a Specialized Command post please?
 FOG
Been asked to fettle a mate's son's Command post. The cable is completely shot but when I looked at the lever end the cable has a really weird ending, not like a conventional nipple at all. On the Spesh site it shows what appears to be a normal gear size nipple. Is there some obscure variation or has a previous owner stuck whatever he had to hand in? Can I use a conventional gear cable which is what I have used on X- fusion posts?Or am I gong to have to order a special part from a Spesh dealer? Your wisdom would be appreciated.
Posted : 20/01/2013 7:13 pm
Normal gear cable in mine and all the others I've seen. Nightmare to keep them running smooth though.
Posted : 20/01/2013 7:51 pm
The first generation of this post used it's own unique cable , for the last couple of years they have used a regular gear inner .
Posted : 20/01/2013 8:21 pm
As a heads up you can get the 1st gen cable from Specialized, but I recall it costs a small fortune, think it was either £25 for the cable alone or you had to buy it with a new lever for a lot more.
I had an issue with mine and phoned specialized at the time, after speaking to one of their techs I ended up just modding the head on a normal gear cable to fit it. I thought they were taking the mick with the cost of a replacement.
Posted : 20/01/2013 8:36 pm
