HELP unique tapered...
[Closed] HELP unique tapered steerer problem
5 Users
So, i've found a unique headset compatibility problem which even FSA say there is no part for. Any (useful) suggestions welcome, although I don't want/can't afford a new fork!
The problem is with the lower end only. I have a Pinnacle Arkose 'cross frame with a tapered headtube, lower OD of 56mm. Designed for a 'normal' tapered fork. In my ignorance I bought a cheap but decent second hand carbon disc only fork with a tapered steerer. Sounds fine, but the taper in the fork is 1.1/8" - 1.1/4". There is no bearing that will fit, and no appropriate crown reducers either...
How i'm loving the proliferation of 'standards'
Posted : 06/08/2013 8:31 am
If you can't find a 56mm to 1.1/4 headset or cannot find a 1.1/4 to 1.5 steerer tube adapter then you might have to get something like a hope HS136 1.1/8 to 1.5 adapter and get someone with a lathe to bore it out slightly. Do you currently have a suitable 1.5" lower headset, bearing and crownrace?
Posted : 06/08/2013 8:50 am
I would give Works Components a shout- they seem to do this sort of non standard stuff
Posted : 06/08/2013 9:19 am
Thanks both -
I do have the appropriate 1.5 bearings and crown race and a hope adaptor from the previous fork...i'll try Works components to see what they say.
There must be so many generic bearings around that there's one with a 52mm OD and a 32mm(+/-0.1mm) / 1.1/4" hole in the middle!?
Posted : 06/08/2013 9:31 am
I'd say milling out the hope adaptor would be the easiest option, a generic bearing wont have the 45 or 36 degree chamfer that a head set bearing will need
a quick search on bearingshopuk.com shows no options either
Posted : 06/08/2013 9:38 am
If the fork is second hand, what was the previous owner using?
Hmm, it would seem that milling the adaptor might be the easiest/cheapest option..
I'm assuming the previous owner had a different headtube lower size - OD 52mm, 47mm bearing seat, which you can get a headset for (FSA No.44 E/CD). I think the design is based on Giant Overdrive (Mk 1) for road bikes.
Thanks for the input...
Posted : 06/08/2013 9:49 am
