Help! Rockshox Reba...
[Closed] Help! Rockshox Reba wiper seal replacement nightmare
I have a pair of 2007 Reba Races I bought recently so decided to give them a lower leg service and change the wipers, easy I thought according to the Rockshox YouTube videos.
So after dropping the lowers I tried to remove the old wiper seals as shown only for the to pretty much disintegrate and have to be pulled, cut and levered out in bits leaving a 5mm ish metal ring inside the fork leg top and a space for the new foam ring.
I got the correct new wiper seal for this model and year but the wiper is too big by a mm or two to go in the internal metal ring. Didn't want to give it to much brute force but as the seal is pretty rigid I am having no luck getting it in.
So am I doing something wrong apart from doing me myself in the first place as I am getting increasingly upset by my seeming ineptitude am considering binning the whole thing am buying some replacements, if only Herc Castro was here to help!
Posted : 17/04/2014 5:33 pm
Warm the seal in hot water - then try ? They are tough to get in !
Posted : 17/04/2014 6:56 pm
Hope free hub seal tool is handy for fitting new seals I've found. Maybe someone local has one
Posted : 17/04/2014 7:10 pm
 nuke
3 piece seal kit or 2 piece?
Pollex-based brute force and a little grease on the sides of the wiper seal is my method...did it for my Revs the other night; my thumbs are still hurting
Posted : 17/04/2014 7:17 pm
PVC plumbing pipe and stick the seal in the freezer for an hour or so first.
Posted : 17/04/2014 7:18 pm
Two piece set, I have one of the Hope seal tools luckily as I have been trying to fix mine and the kids bikes myself which is just the right size.
I will give it a try with the hot water treatment and the freezer too followed by brute force and ignorance, first time something has beaten me so far. ๐Ÿ™‚
Posted : 17/04/2014 9:40 pm
