Ordered the wrong BB for my 2012 Five.
I thought I could just order a Hollowtech 2 68/73mm one and it would be fine. Turns out not.
What measurement am I missing?
Can anyone recommend any deals around at the moment?
Last one I ordered was accidentally the right one from Rose bikes.
Is it the BB90 bit I needed to check?
Strange. It's just a standard British threaded bottom bracket, so an HT 2 should fit (unless you got an Italian threaded one or something).
One I had to send back was small. Could tell looking at the box it was too small. Thought the 69/73mm bit would be the only thing I needed to check
It should fit.
Is it a Shimano bb ?
It was this one before I sent it back
http://www.chainreactioncycles.com/mobile/shimano-xtr-m970-bottom-bracket/rp-prod38336
Small it what way ?
Swear mines bb60 not bb90
I think bb90 is xtr cranks and bb60 deore,slx, xt I could be completely wrong though.
Small in the diameter way of the cups.
Can anyone find one that should fit on crc?
We've just had a road HT2 BB through with smaller diameter cups, and an adapter to fit into the original tool, not sure if MTB ones are going the same way.
