Im considering a dropper seatpost for my Heckler..
Looking for advice on what to choose?
Reverb/KS, etc.....
thankyou for any help!!!
And more to the point - which ones provide any kind of layback?
Issue 87 has a group test.
Don't think any have any real lay back. Think the Thomson has a couple of mm but that's it.
KS have some options with layback. Decent posts too.
KS Dropzone has about 20mm layback, one of the reasons I bought it. 1year old now and still performing perfectly, very happy with it, especially as it was only £115
Cheers - and sorry for the thread hi-jack
Reverb, hands down
Layback on a dropper post isn't a great idea IMO, your weight will force the stanchion in to the post at an angle and wear the seals and stanchion faster.
Currently heading to the States soon and thinking of bringing one home, but at a quandry which one also, some real world reviews would be great as opposed to the mag marketing hype of a couple of days round a dry trail centre. At the minute I like the the fox doss and its just £200 in USA.
slowrider - MemberLayback on a dropper post isn't a great idea IMO, your weight will force the stanchion in to the post at an angle and wear the seals and stanchion faster.
Nope. Or at least, not in a way that's noticable after 3 years of constant year-round use.
I've got two reverbs one Ks lev and a fox doss. the Ks lev wins easily in my year odd of using all three.
I've had my Reverb for over a year now and can't fault it at all.
I really like the lever placement when run under the bars and it's action is really good I think.
fd3chris what do you think of the fox doss?
More than happy with the KS posts I've had, ran an i7? (KS 27.2 jobby) for years without a hitch, stripped it once and it was mint inside.
Then got a Dropzone, still happy.
My frame only has bits for a cable dropper, not a hydraulic one or Id probably have got a reverb.
The doss is very well built, if not over built. The action is smooth if a little fast on the return. The lever is large as most reviews state but I really like the dual lever set up and the size of it is excellent if you have big hands or are wearing gloves. Overall it's a quality bit of kit.
+1 for Reverb as reliable and great to use (but not used others).
Cheers fd3chris will probably go for the doss can pick one up in the states for £200
That's where I got mine from. You won't be disappointed.
Doubt that your weight will damage a dropper post as mentioned above
Weight is only fully on the post when you're sat on it - any other time it's moving or out of the way.
Stanchions and seals don't take the weight - the spring does.
I have had my Thomson for 4 months now and its awesome. Smooth action and practically zero play. Thomson quality of finish is (and always has been) the standard by which others are measured. Not that cheap but worth it in my book.
Some pro's and Cons
Reverb (missus owns)
Pro's
Longer history and seem to have fixed the early faults that saw a large number of returns.
Option for Internal routing if frame allows
Lever seems to be able to be bled by chimps
matches with MMX shifters for neatness
Cons
Still see failures
External hose routes to the saddle end and has to move - hoses kink (death) and hoses interface with the back wheel
Fox (observed not tried)
Pro's
Made by Fox
Cons
Made by fox
3 positions
Lever big enough to steer oil tankers
KS Lev (owned)
Pro's
Solid
Reliable
Cable entry at seat clamp
Nice lever matches with ODI grips
Cons
Not sure on long term reliability heard some issues (less than with reverbs though)
Anything else, read the reviews in the mag but they didn't seem to equate to the final judgement (like most mag reviews)
Personally it's between the reverb and KS for me, 3 positions is limiting, thompson have not had a good winter run yet to test it properly and fox hasn't had the volume or the time for a proper reliability test either.
DOSS, only post that the germans couldn't break.
Lever in place of your front shifter and you're good to go - endurotastic
[i]Currently heading to the States soon and thinking of bringing one home, but at a quandry which one also, some real world reviews would be great as opposed to the mag marketing hype of a couple of days round a dry trail centre. At the minute I like the the fox doss and its just £200 in USA. [/i]
Based on the number of Dropper Post issues I wouldn't be buying one from anyone else except a UK-based retailer.
Thanks for helping out , think I'll go with the reverb.
Now I need to find one at a good price.......
Chris.
Chris reverb at wiggle £170ish
Fudge,, thanks for the heads up.
Chris.
