Help required - bot...
[Closed] Help required - bottom bracket keeps working loose - advice please?
My square taper bottomm bracket keeps working itself loose on the drive side. (2006 P7 frame)
I need to remove the drive side crank and re-tighten it every 3-4 hours of riding.
Do I just need to have the thread re-tapped or is this a sign of something more serious?
Thanks
Pie
Posted : 02/03/2010 1:18 pm
either the taper or the hole in the crank (or both) are knackered and need replacing. I replaced 3 left hand arms before realising it was the BB taper that was bad (from new) ๐Ÿ™ As you retighten, the hole in the crank wears, accelerating the process - mine got so bad it would only last about a mile from being tightened with a pipe over the allen key...
Posted : 02/03/2010 1:22 pm
Why not just use some thread lock?
Used these [url= http://stores.shop.ebay.co.uk/StarLoc-Five-Star-Adhesives-FMK_Threadlock-Retainer-StarLoc_W0QQ_fsubZ6QQ_sidZ138190498QQ_trksidZp4634Q2ec0Q2em322 ]GUYS[/url] superglue and epoxy and it's great. Don't see why their thread lock should be any different.
Posted : 02/03/2010 1:30 pm
Is it the crank or the bottom bracket? If it's the bottom bracket, it may mean that it's on its way out, and is sticking occasionally and unscrewing as you pedal.
Posted : 02/03/2010 1:43 pm
It's the actual bottom bracket cup that is coming loose, not the crank arm. I'll try putting in a new bottom bracket and hope that fixes it.
Thanks
Pie
Posted : 02/03/2010 2:42 pm
Piemann,
Did you manage to resolve your BB issue.
I too have a 2006 P7 and the driveside cup on a Square Taper BB is also coming loose.
I havent ridden it much this winter, but I think it's only been 1 or 2 rides since I last tightended it up.
Posted : 16/02/2011 9:47 am
Just use soem thread lock on the BB cub threads ๐Ÿ˜€ it should take care of that ๐Ÿ˜‰
Posted : 16/02/2011 10:49 am
I was considering that, but it's not something that I have ever had to resort to before on any of my bikes.
The frame is going back to Orange for a respray, so they are going to give the BB shell the once over.
Posted : 16/02/2011 12:31 pm
