help required
[Closed] help required
just installed a new sram x-9 rear derailleur and a shimano xt e-type front mech this is the first time ive done this my self, Ive also renewed the inner cables for both, im just abit unsure as to how much cable tension should both have because when im going into about 4th gear the chain is like a piece of spaghetti lol if i can get the tension correct i can start messing with the high and low settings unless this needs to be done first. thx
Posted : 12/07/2010 7:30 pm
search "setting up mountain bike gears" on youtube follow that
sounds like your chains too long to me
Posted : 12/07/2010 7:48 pm
no cause my chain was fine but now its like spagetty with this new set up
Posted : 12/07/2010 8:19 pm
i was doing this with the bike upsidown on its seat, i tried to hold it the right way up and do it then but wasent as bad, ill try again tomz when i get it on a proper stand, the chain starts to get really saggy in gear 6 onwards but then it dosent go into 9 just gets to 8 :/
Posted : 12/07/2010 9:11 pm
