Hope M4 post to IS ...
[Closed] Hope M4 post to IS help
 krag
[#1792786]
I've just bought some Hope Mono M4s with 203mm rotors.
Forks are rock shox domains, post mount. Any ideas what adaptor I need to get these to work? I know I can ring hope in the morning but thought I'd ask..
Cheers.
Posted : 12/07/2010 7:25 pm
You need a Hope Post mount to IS adapter. Google is your friend. Think mine eventually came from Wiggle for about a tenner. If you've got 203mm rotors you also need a couple of small washers between post mounts and adapter. If you have 203 compatible m4s then god knows what you do as the Hope adapter adds 20mm. So you need a bigger disc. Standard 180mm calipers + adapter requires 200mm rotor
Posted : 12/07/2010 7:38 pm
 krag
Yeah, that's the bit I was stuck on as I read on another thread where the 183 rotors would get pushed up to 203 with a IS/post adapotor but it was a bit of a spur of the moment purchase eek 🙂
Posted : 12/07/2010 7:41 pm
If the calipers are IS (No 8), then your rotors are 200mm, not 203mm. Without going to 220mm rotors, there's no way you're getting those calipers on that fork.
Posted : 12/07/2010 7:46 pm
 krag
So what's the options other than stick them on the classifieds, smaller calipers?
Posted : 12/07/2010 7:52 pm
What is the rear caliper set-up? Is that using a 200mm? Hope don't (didn't) do an IS caliper for 200m rear...
Posted : 12/07/2010 8:02 pm
 krag
OK, make sense now. The caliper on the front is a 9:74 so thats the 183, just need a standard post to is mount I think.
Posted : 12/07/2010 8:26 pm
No, the 9.74 is PM and needs a specific adaptor to fit a specific disc. If the disc is 203mm (not the 200mm I though it was when I thought that the caliper was IS mount) then you need mount adaptor C (check [url= http://hopegb.com/voir_hbm_image__tgrandeimage_1.html ]here[/url])
What is the rear caliper and disc?
Posted : 12/07/2010 8:45 pm
